1 - 1 of 1 Posts
1-877-MOD-POWR
Have dented, missing or damaged spark plug tubes on your 5.0 Mustang or F150 or 5.2 GT350/500 ? These are what you need! We have found the easiest way to remove the old tubes is to cut them 3/8" above the head surface to allow access with a grinder bit to put 2 small cuts in the tube, this will allow you to remove the remainder in 2 pieces. Manufactured from billet aluminum.
Includes QTY 4
1 - 1 of 1 Posts
