1 - 20 of 29 Posts
I have a 2007 dodge durango limited and the rear passenger power window will not go up but all others work fine, need help wife is away camping with kids and is freaking out.
Regulator most likely, the cables break, I've replaced lots of them, easy job and the regulator/motor assy. is about $150 aftermarket.
My 04 durango rear window wouldn't go up with the rear door switch, but would with the main switch on the drivers door.
thanks guys will I be able to jump the motor and get the window up till she gets home so I can repair or replace the regulator
If the regulator cable is broke, you won't be able to roll it up unless you take door panel off and prop it up with a 1x. The only way you can jump the motor is if the switch is bad. When those cables stretch or break.......................it's done. Simple fix, and O'Reilly's carry the door regulator and motor assemblies for around $100
Discussion Starter #7
if I pull the door panel off can I pull off the connector and test to see if I have 12v to the connector so I know the switch is good, and assume at that point my motor is bad.
You can, but once you get the panel off you will probably see the cables laying in the bottom of the door and there will be no need.
Drag Week Survivor
You also may have to JB weld the window clip back onto the glass. Often times they are loose.
Take the door panel off and make sure you are getting +/- at the connector. Door harness' and switches can also be an issue, but regulators are very common.
Banned
Very disappointing.
I havn't got to say it yet, so, HIT THE NEWBIE THREAD AND SIT ON A FUCKIN CACTUS DOUCHE NOZZLE!
Banned
It was your turn, we were waiting... :p
Good save! almost didn't make the first page. Lol
1 - 20 of 29 Posts
