driving home yesterday i was doing about 75 on the freeway when i noticed my abs light came on, i figured id check it out before work but within 10 miles my bearings blew out and my wheel was only on by the caliper mount around the rotor. I fixed it last night with a new hub assembly but how many miles is typical for these to go? id like to change it before it blows out with no warning like this.
p.s. why the fuck would you not put serviceable wheel bearings on the 2wd model? i can't believe you can't grease or adjust the wheel bearing preload. basically a little wear and it bangs around and blows out?
