1 - 11 of 11 Posts
BTW I live in South Africa.
2002 Subaru Impreza WRX GDA bugeye 5 speed manual sedan
Engine mods
CP Pistons
Eagle rods - ARP bolts
ACL race bearings
STi Nitrided crank
ARP Head studs
STi 11mm oil pump
Cast impeller water pump
GFB blow off valve
VF34 turbo
4 x STI 550 cc injectors
MRT Parallel fuel rail with dual fuel regulators
Walbro gss 342 fuel pump (255lph) in tank pump.
Fuel anti Surge tank
Charge cooling
MRT STi Larger hood scoop
APS intercooler splitter
MRT top mount intercooler.
Samco intercooler hoses
Samco intake hose
Exhaust
HKS 3 inch hi power exhaust
decat up pipe
Suspension mods
Whiteline group 4 coilovers
MRT/Whiteline front and rear sway bars
Whiteline alloy rear droplinks
STi rose jointed front drop links
Rear camber bolts
Alu front/rear control arms
Other
Aquamist 2d
Aquamist DDS3
Aquamist Silicon I/C to throttle body hose with two Aquamist jets
Ecutek remap with dual boost maps and user-tuning
Process west oil cooler
Aluminium radiator
Samco Rad hoses
Samco Ancilliary hoses
STi I/C water spray kit
Brakes
K-Sport racing 8-pot 330mm BBK
DS 2500 ferodo pads
Goodridge Braided brake hoses
Gearbox
Front Torsen LSD
GFB quick shift kit
Kartboy poly bushes
Interior
Ecutek Dash monitor
Delta dash kit
Knock link kit
SPA oil temp/pressure gauge
Lamco Boost gauge
Innovate A/F DB-gauge
Sparco harness bar
Sparco camlock 4 point belt
SMY Dual Dash Bezel Gauge Pod
Exterior
Morrete head lights
Morrette Projector HID upgrade
MRT Cibie headlights
Side strakes
(Total wattage on road = 420 W light output)
STi fog light protectors
WRB Painted side skirts
STi rear boot spoiler
Blue twisted I badge
OEM upgrade to White indicators and reflectors.
OEM brake cooling ducts
OEM transmission undertray
Discussion Starter #8
Added the following
Td05 20-g
up pipe
new header tank
new powersteering lines
new boost controller
new boost control lines
New FPR
New radio
Discussion Starter #10
Upgrades installed recently
Mishimoto X-Line radiator
https://www.amazon.com/Mishimoto-MMRAD-WRX-01X-Performance-Aluminum-Transmission/dp/B001EQBRII/ref=sr_1_sc_1?s=automotive&ie=UTF8&qid=1527931484&sr=1-1-spell&keywords=mishmoto+xline+radiator+wrx
Mishimoto radiator clamps (Blue)
Mishimoto intake pipe
Mishimoto coolant header tank
Mishimoto 1.3 bar radiator caps (x2)
TD5-20g turbo
TR adjustable WG actuator - currently 0.8 bar spring(additional 1.2 bar spring)
Grimmspeed upipe
Deleted OEM egt sensor.
New MAF sensor
Replaced crank re-breather pipes
Cleaned all injectors
Replaced both FPRs
Replaced all exhaust gasket
Replaced all power steering hoses. (what a B!tch to do- got a 2 cm deep gash in my palm during this procedure)
Replaced OEM radiator overflow tank cap.
Replaced OEM washer bottle tank cap.
Replaced radiator top hose
Replaced both belts (AC and ALT)
Replaced cambelt and all pulleys.
ICE upgrade
Pioneer's AVH X391BHS with reverse camera and front camera.(the cameras have not been installed as yet)
Metra subaru harness adapter.
Not installed (in box)
Grimmspeed three port boost control solenoid
Mishimoto -Rockstar three port catch can - for Crankcase
Mishimoto small catch can with brass filter - for Heads
https://www.amazon.com/Mishimoto-MMBCC-MSTWO-RKST-Compact-2-Port-Baffled/dp/B00V5R1YTI/ref=sr_1_sc_1?s=automotive&ie=UTF8&qid=1527931437&sr=1-1-spell&keywords=mishmoto+rockstar+oil+catch+can
Mishimoto Hoonigan oil cap
https://www.amazon.com/Mishimoto-MMOFC-SUB-HOONRD-Subaru-Filler-Hoonigan/dp/B01KI4XKY0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1527931365&sr=1-1&keywords=mishimoto+hoonigan+oil+cap+wrx&dpID=41DXa%2BtCBQL&preST=_SY300_QL70_&dpSrc=srch
AEM Cold- air intake
https://www.amazon.com/AEM-Cold-Air-Intake-System/dp/B000WOIE02/ref=sr_1_2?ie=UTF8&qid=1527931229&sr=8-2&keywords=aem-21-474b
AEM water sock for CAI
https://www.amazon.com/AEM-Filter-Problem-Solution-Sucking/dp/B01B3TRK54/ref=sr_1_fkmr0_2?s=automotive&ie=UTF8&qid=1527931324&sr=1-2-fkmr0&keywords=aem+cai+sock
1 - 11 of 11 Posts
