1 - 20 of 30 Posts
Got a call from a friend with a noise coming from under his valve cover. Truck is a 2001 F150 with the 4.6 and 250,000 miles. Good oil pressure. Any very common issues with these engines? I know thats a ton of miles....Just had the transmission overhauled 2 days ago. I was thinking maybe a converter bolt loosened, but doesn't make sense with a noise under the VC. Passenger side.
Is he positive it's under the vc, I've been fooled by noises before, I would guess worn out chain and or chain guides.
^^ this
Could be broken rocker or spring though. Pull the cover and take a look. They aren't bad of a pull.
Discussion Starter #9
Thanks,
Just saw a youtube video on a clogged oil restrictor under the vc too.
Yes. 4.6's have "followers" which are interchangeably called rocker arms.
Discussion Starter #12
They aren't directly cam to valve action. There's even hydraulic lifters. ("Lash adjusters") in the head.
Discussion Starter #15
Just got a call from him, appears a spark plug blew out. Hope it loosened and not stripped :confused:
Discussion Starter #17
with 250k, i bet its not the first one to blow out. fantastic design by ford that rectified a few years later with spark plugs that come out in 2 pieces!
I have one of those 5.4's. He claims it only threads in with like 5 threads? Sent me a pic of the old plug and I thought it wasn't installed all the way. Just threaded about 1/3 of the threads. Is that correct?
OL 10.5 TTF
waiting to make a pass!
Your buddy is not very good a describing problems.
Stripped/blown out plugs is common.
Discussion Starter #20
I know. Just a young college kid trying to learn.
I think it happened last night on his way to college. texted me first thing.
1 - 20 of 30 Posts
