My friend has a 2001 Chevy 3500 2wd 8.1 with 24,000 miles cab and chassis he used to use for a spray rig(landscape spray) and the kid who drove it never checked the oil and locked up this problem plagued motor. Took it out, took the pan off and the mains are smoked and not rebuildable. After exhausting research I found this motor is no longer supported by GM, one crate motor left in the country for $9,000. Called Jasper and all the other junk makers and they want $7,000 but haven't performed ALL GM suggested upgrades. This engine was littered with problems from inception and apparently is great if you take care of it.
What would be a good idea for this truck to be remedied? I looked into swapping a Vortec 360 and it is a full blown project, even with a donor truck so you get all the parts. This truck is cherry and unfortunately is not worth more than $1500 as is. What is a good method to not lose all value on this truck? Thanks in advanced!
