1 - 20 of 24 Posts
· Registered
Hey all,
I'm currently running a 101mm turbo 23 degree headed alky small block chevy setup. I'm looking to step up and wondered what all your thoughts were on the best cylinder head available for making 2000+HP from a turbocharged small block chevy???
Also, to make the HP that I'm chasing would I be better off going to a 106mm or twin 88mm turbos?? or will the 101mm do? if not, will/would the twin 88's spool as quickly as the 106?
· Registered
CFE has the new SBX head too that's symmetrical exhaust. Other options will be the old pro-stock truck canted valve heads.
· Registered
Haddad manages a fair bit more from out of the box 23 deg AFR heads, alky and turbos with alot less potential (GT35Rs). How much power is the combination making currently? Should be good for a lot more than mid 9's in a mid sized car.
· Registered
Steve Morris just made 2101 with a 509 and a pair of 80mm turbos with a c&s 900cfm carb............
· Registered
Get a head that is a heavy casting. Curtis has one that would work great out of the box called his 18 deg Monster at a very good price.
www.raceflowdevelopment.com
That is Cboggs a contributing member here at YB. He also is direct with Dart, Edlebrock and Brodix as a WD.
Ed
· Registered
X2 CFE makes some killer shit.
· Registered
Discussion Starter · #16 ·
why don't you try what you have got you have only ran 9.6 and have not ran the new combo it's albout going out there and racing not googleing
Wow, why don't you try getting your facts right first........ Firstly this post is 2 years old. Secondly this question was posted by my brother as I wouldn't tell him at the time what my new combination was going to be so he figured he'd narrow down the option lol. Thirdly the car that ONLY ran a 9.6 @ 145mph is a mate of mine who was ONLY on his first pass in a brand new blow through carby car which was ONLY on 10psi boost in ONLY a 3640lb car with ONLY a standard leaf spring suspension and ONLY a 28 x 9 tire. He has since decided to change his fuel system etc (he's changed to injection on alky etc etc) to what my own personal old car/setup was back 4 years ago which made great power and destroyed anything in Modified Street, he will be coming out in January 08 and is looking forward to hopefully running an 8.
Thanks to those who responded, I agree those are all great cylinder heads companies.
· Registered
Discussion Starter · #19 ·
Because you'll find that rule didn't exist back then until I ran a number which was quickly followed by the 88mm rule. It's all good though mate, I guess that's life. At the end of the day I built that car to do something different and had a lot of fun doing it. I still have that combo sitting there (including a 88mm) if once I've finished having some fun bracket racing I can stir things up again, but for the mean time I'm enjoying helping out some others and building a new turbo project :)
· Registered
all u help is yourself and stir shit on the aspa forum-
dont bring or start this shit on here-
1 - 20 of 24 Posts
