I don't understand your setup.
Are you saying your TB is armed only when in first gear and then there is a seperate TB button for staging?
If so, then it will wire up just as shown. The switch in the shifter is your arm switch and everything else is the same...
This is kick ass. I tried to do this about 2-3 years ago, but had used a PWM controller instead of the timer. The trans brake just couldn't meter pressure well enough with the PWM so it was jerky as hell and really didn't work.
Looking for an idea on what size cells you guys are running . First ever methanol turbo build running front mount tank sbc single turbo mechanic fuel pump HolleyEFI drive to the lanes 1/4mile Racing mostly is 3 gallons enough?
Thoughts on these cam specs for a twin turbo 347 looking to shift around 7500 + and make around 1350 + hp:
I can't say that I've ever ran a turbo cam with so much lobe separation before...any ideas of what the idle quality and lower rpm power response will be, if any, with this cam?? I've also...
