1 - 20 of 27 Posts
Is it just me or are these impossible? The bigger the fitting it seems the harder they are to do. Also my AN wrench went to shit. It spread and just slips off and uglified my fitting. Whats the secret?
I never had a problem putting together an lines until recently. Anyone else find it to be a bitch to get aeroquip fittings to start recently? I think it is the hose. Sometimes they still are easy, but start a new roll of hose then you struggle 30 minutes to do one fitting.
I always felt its the oppositte, the smaller ones are always a pain to me, the bigger ones seem easier to me. I hate doing -3,-4,-6 and -8 and up seem easier. I always use wd-40 on the hose,fittings and threads to make it easier to assemble.
On the roller...
Yup. Brake lines suck ass.
THREAD KILLER
I oil the hose a nipple's and anti-seize the threads, mark the hose so you know it doesnt push back as the fitting is tightened and boom done.
What he said ^^^^^^^^
This. Plus I use Earl's oil and mark the hose.
Senor Frog
I noticed many brand of fittings are made stupidly
If a fitting is a -12 then why are they not -12 where it needs to be assembled or
atleast an AN size ? I have a -12 yesterday and the part that needs to be wrenched for tightening is not even an AN size ,so I have to use an adjustable wrench instead of a non scratching Alum wrench......Dummys
and use the vice clamps works great . and as someone else mentioned when it gets rough turn back a 1/4 turn and re tighten but that usually happins with the small ass ones
Aviation Section
That is true, if you are tempted to buy the cheap hose you will have fitment issues, I did, and now I only get the good stuff. You can make the cheap hose work, just go around it twice before you cut it with masking tape, cut with a high speed cut-off wheel slowly and leave the tape ON so the hose won't start to fray, put your fittings on and clean the hose interior and you are done. Don't forget to use oil. Dave
+1. -3 & -4 lines were always a huge headache for me.
Discussion Starter #19
I'm using Titan brand fittings which is the same as Jegs house brand. They go together fine but I get down to the last five threads and it stops. I use engine assembly moly , WD -40 it just won't go any further without mauling the fitting. And of course I'm one of those guys that can't have a boogered up part anywhere on the car or it will bug the shit out of me. Ive had no issues with any other sizes of that brand. Nothing has leaked or given me any trouble until I got the -20 for.my lower radiator hose
Mike Walsh
X2
1 - 20 of 27 Posts
