Have had similar issues with the 002. The 003 does a better job all in all.I originally bought the LNC-002 for the timing function to pull timing for nitrous but it didn't work very well and broke up alot so I disabled that feature and just pulled it in the tune.
That's an interesting idea. Are you saying that you have a trigger wire that would activate the traction control timing table while on the 2-step?You can wire a trigger on the traction control pin and use the traction control timing table in the PCM to pull timing while on the two step to really generate some boost.
There are a few parameters like timers that need to be edited to make it work right but is def doable!
No it will still need either the lingenfelter or MSD box to cut spark as a rpm control/rev limit. The traction control table will be wired into the box so that when the box activates it pulls whatever timing is entered into that table.James, if you can do that with the traction control table then theres no need to have to box at all then huh? You'll be getting the call to do the tuning on this anyway.
