SELLING MY 73' NOVA DRAG CAR. CAR IS FULLY BACK HALFED, CURRENTLY HAS MINI TUBS AND SLIGHTLY NARROWED REAREND CAN BE MADE BIG TIRE WITH FULL WHEEL TUBS AND SHORTEN THE REAREND FURTHER THAT'S IT!!.
INTERIOR: 14 POINT CAGE W/ CURRENT 8.50 NHRA CERT, ARC SWITCH PANEL, AUTOMETER GAUGES, PRO BANDIT SHIFTER, GRANT REMOVABLE STEERING WHEEL, 7AL2 IGNITION, RACEPAK DATA LOGGER, FIRE EXTINGUISHER.
REAR: 4 LINK REAR SUSPENTION, ANIROLL BAR, DOUBLE ADUSTABLE REAR SHOCKS, WHEELIE BARS, 4 PISTON WILLWOOD DISC BRAKES WITH SLOTTED AND DRILLED ROTORS
FRONT: QA1 UPPER AND LOWER CONTROL ARMS WITH SANTUFF SPRINGS, DOUBLE ADJUSTABLE QA1 SHOCKS, 4 PISTON WILLWOOD DISC BRAKES WITH SLOTTED AND DRILLED ROTORS
WHEELS: REAR HAS 15X10 WELD PRO STAR WHEELS WITH 29.5X11X15 HOSSIER SLICKS WITH CURRENT SET UP CAN GET A GOODYEAR 29X12X15 SLICK FRONT WHEELS ARE 15X4 WELD PRO STAR WHEELS WITH MICKEY THOMPSON FRONT RUNNERS
REAREND: CHRIS ALSTON FAB 9 WITH BACKBRACE, HAS WHEELBAR BRACKETS WELDED ON, HAS MOSER ALUMINUM 9" THU BOLT CASE WITH CURRENT 5.00 GEARS AND 40 SPLINE MOSER GUN DRILLED AXLES, 4" ALUMINUM DRIVE SHAFT WITH SPICER HEAVY DUTY NO LUBE RACING U JOINTS AND HARDENED BILLET TRANS YOKE
TRANSMISSION: CURRENT TRANS IS A MIKES TRANSMISSION ULTIMATLE TURBO 400, REIDS BELLHOUSING AND CASE WITH CURRENT CERT, BILLET INTERNALS AND DRUMS, GEARS 1ST 2.48 2ND 1.48 AND 3RD 1.00, BILLET TRANSBRAKE, CONVERTER IS A COAN SPRAGLESS 7000 STALL WITH ANI BALLOONING INTERNALS, INLINE TRANS COOLER WITH ELECTIC FAN, TRANS AND COVERTER ARE NEW ONLY 4 PASSES ON EACH
ENGINE: 427 SMALL BLOCK CHEVY BLUEPRINTED AND BALANCED, DART LITTLE M BLOCK, 4.125 BORE WITH 4.00 STROKE, 4340 CRANK AND H BEAM 4340 RODS WITH L19 BOLTS, DIAMOND DOME PISONS WITH TOTAL SEAL RINGS. CUSTOM ENGINE BUILDER CAM, DOUBLE ROLLER TIMING CHAIN WITH CRANK TRIGGER, FLUID SFI FRONT BLANCER AND SFI REAR FLEXPLATE, AFT 245 RACE PORTED HEADS W/ UPGRADED VALVES, SPRINGS, RETAINERS AND KEEPERS, T&D SHAFT ROCKER ARMS 1.7 RATIO, SMITH BROTHERS 3/8 PUSHRODS, ISKY RED ZONE LIFTERS, WILSON MANIFOLD/EDELBROCK SUPER VICTOR MATCH PORTED MAINIFOLD WITH NITROUS FOGGER BUNG WELDED IN, WINCHESTER METAL WORKS CUSTOM VALVE COVERS AND A CUSTOM DEVINCHI 1080 DOMINATOR CARB. 180 AMP ALTERNATOR AND VACUMN PUMP
COOLING: MAZIERE 55GPH ELECTIC WATER PUMP AND BE COOL RADIATOR, FLEXALITE ELECTRIC FAN
FUEL SYSTEM: PRODUCT ENGINEERING 500 PUMP WITH FILTER, PRODUCT ENGINEERING REGULATOR, PRODUCT ENGINEERING BYPASS SYSTEM, 20 GALLON ALUMINUM FUEL CELL
BRAKES: AS SAID ABOVE 4 WHEEL WILLWOOD DISC BRAKES, FOUR PISTON CALIPERS WITH SLOTTED AND DRILLED ROTORS, WILLWOOD MASTER CYLINDER, LINE LOCK
ENGINE WAS REBUILT MAY 2021 AND HAS 17 PASSES ON IT, TURBO 400 WAS PUT IN IN JULY AND HAS 4 PASSES ON IT.
CAR RUNS VERY VERY CONSISTANT HEAT DOESN'T AFFECT IT.
CAR RUNS 9.85 @ 135MPH
CAR RAN 9.77 WITH POWER GLIDE @ 137 MPH
CAR HAS 6' COWL HOOD AND FRESH PAINT. HAVE LOTS OF EXTRAS. CAR IS TURN KEY READY TO MAKE A PASS. I HAVE BLUEPRINT SHEET FOR ENGINE AND TRANS AND RECIPTS FOR EVERYTHING. NOTHING WRONG WITH THE CAR JUST GETTING OUT OF RACING.
FEEL FREE TO EMAIL/TEXT FOR ANY QUESTIONS [email protected]
(650) 255-1692 text
ASKING 35,000 OBO
Will also sell 24’ enclosed trailer for $45,000.00 for everything
EXTRAS!!!!!!!!!!!! HAVE LOTS OF SPARE PARTS: FUEL PUMP AND REGULATOR PLUS SPARE FILTER AND REBUILD KIT, SPARE WATER PUMP MOTOR, SPARE CARBURATOR, SPARE IGNITION SYSTEM (MSD POWER GRID), SPARE VALVE COVERS, VALVE COVER GASKETS, SPARE INTAKE MANIFOLD GASKETS, SPARE ROCKER ARMS, SPARE PLUGS WIRES CAP AND ROTOR, SPARE TIRE TUBE, SPARE COAN POWER GLIDE TRANSMISSIO WITH REIDS CASE W/ CROSSMEMBER AND SHIFTER GATE PLATE AND CABLE BRACKET, SPARE CARB REBUILD KITS. i ALSO HAVE A NITROUS PRO FLOW FOGGER SYSTEM WITH 2 BOTTLES, SPARE SEAT, TWO SPARE REAREND GEAR SETS WITH REBUILD KIT 5.00 AND 4.11
(650) 255-1692 text
ASKING 35,000 OBO
