61 - 80 of 326 Posts
Discussion Starter #61
yeah I love the looks but kind of thinking about going to stockers again, I just have some money wrapped up in these. I might flip the headers upside down if they will clear the steer box and a-arms and then run the coils on the valve covers...
Discussion Starter #62
Well engine is in! I was a little worried, the more I would read about people installing Lsx into x-bodys people had tons of problems with the mounts and oil pan clearance. I am very happy I spent the money on the autokraft sheetmetal pan. The clearance from crossmember to floor is great and there is plenty of space between pan and crossmember. And the ebay 1" setback plates worked great as well. Its time to start on the hotside, I kind of wish I would of went the twins route but I have to many parts to turn back now.
Damn, another build that makes me wanna' sell my current Gen I SBC stuff and go LSx, shit! Good choice on the valvecovers, those are the ones that I'da' chosen, they seal well but still look "tough". Great build!
---==Temio Williams
Yuba City, CA
WHAT?
Very nice!!!
How bad did the SW tubes hurt you? They look like a work of art!
Lead.
Discussion Starter #67
Progress Update....
Its been a while due to work overload this summer and some motivational issues with the heat but its picking up steam again! Got all the front end sheet metal back on the car, Figured out the accessory drive and belt setup, car is now in the process of getting the turbo stuff all built. I wanted to make sure I am not limited to the 76mm with the build so there has been a great deal of planning going on. I am mocking up a pt4788 so when I build my next motor over the next year I can shoot for 1000whp+
Progress Update....
Build is bad azz
Awesome looking setup. Have you considered cutting the collectors off and shortening up the primaries to move the collectors back away from the radiator to give you more room? Looks like that bend in the merge pipe is gonna have to be tight to clear with them sticking out that far.
Discussion Starter #71
yeah the drivers side will be getting cut back a bit and then its going to merge actually down low by the frame and come back up to the flange for the turbo. Really taking all measures so that I am only limited by a t4 flange and nothing else when I step up in turbos. I have full intentions of going to a pt4788 next.
is that a 4" intercooler and does the grill fit?
Discussion Starter #73
sure is and yes it does. I obviously cant run the hood latch and dont care about the grill filler but the grill and headlight bezels work fine
Discussion Starter #74
More of a final product of the intercooler mounting and started getting ideas for mounting the turbo. The turbo mounted currently is the pt4788 that will be used next year once the built 6.0l is done. So everything is being fitted with that turbo in mind but with the 5.3 the mp 76 q trim will be used. in the next 1-2 weeks the hotside will be done and progress will be picked up. Its starting to come together
Discussion Starter #75
progress update:
Well I have made a ton of forward progress on the car over the past month or two. The entire hot side is complete. and the cold side was completed as well. At first I was going to be using all mild steel but went to stainless and very pleased that I did on the hot side. Got the coils custom mounted, twin a 1000 pumps mounted, driveshaft hoop and a bunch of other miscellaneous stuff done. Got the new driveshaft made and installed, mounted remote trans cooler and shifter mount fabbed up. I am excited to get the forged 370 in it and get everything plumbed and wired then hit the rollers.
I am currently changing the one intercooler pipe to use the pro flo intake since I will be putting in the forged 6.0 before I get it tuned here at the first of the year and shoot for 1000+ RWHP.
I may be switching to a cable drive fuel pump or goto a magna fuel pump along with upping from the 83lb injectors to 160's as well. So I will have no issues making 1000-1200 on corn. I am not going to stop until I make it deep into the 8's.
Really good looking setup cant wait to see some video's.
Discussion Starter #78
Yeah the passenger side headlight is a velocity stack I'm gonna maybe run the headlight if I do some true street events.
Discussion Starter #80
Got the new intake intercooler pipe finished
