1 - 15 of 15 Posts
Looking for a LSX style or similar size high amp 16 volt alternator. Anyone know where I can find one? All Im finding in the "mini" alternators are 55 amp and that isnt going to cut it with all the electronics Im running.
Before anyone says it, I cant run one high mount on the head or anything either, my turbo setup just wont allow it and I would rather not re-do all my hot side if I dont have to.
Discussion Starter · #8 ·
I wouldnt even know how to go about all that. Im not electrical expert by any means. Heres what I plan to run other than the usual headlights, tail lights, turn signals, no radio, no ac/heat, no power anything.
Magnafuel Protuner 750 fuel pump
Meziere 55gph remote water pump
16" Hayden electric fan
9" electric fan on tranny cooler
AMS-1000 Boost controller
Megasuirt EFI w/160lbs injectors
Innovative LC-1 wideband
Does that help?
Discussion Starter · #10 ·
out of work hair dresser
Does that help?
125 amp at 12 volts Denso alt will fit and is all you need. A 105 will suit your needs with a 16 volt system.
Discussion Starter · #13 ·
^^^ i dont think u would need more the 120-140 amps-
what voltage battery have u got now-
Nick--
Had a 12 volt but it took a dump on me along with my 12v charger so thats why Im considering swapping over.
Thanks for the help!
I had too many people tell me if I had the chance make the switch but I dont know if it would be worth the expense. The only thing I hear is "my lights are so bright" and "my fuel pump runs alot better" but with the setup I have I think 12v would be sufficient so I dunno.
I use the stock LS alternator a local shop upped to 145A along with a 'voltblaster' (casper electronics) that raises the voltage (TPS activated) output to 15V+ at WOT.
Been working fine like that for years, during a pass the voltage hits 15.5V according to the BS3 and the rest of the time it puts out normal voltage. I run engine fans, electric water pump, 7503 magnafuel pump, BS3, two widebands etc and have no problems with a 12v battery at all. Have had the same optima in the car for three years and it still works as well as the day I put it in the car.
1 - 15 of 15 Posts
