1 - 11 of 11 Posts
600ci Sweet Sixteen cylinder head 60mm camshaft x patern .937 12.5 compression Ratio max rpm 6800. This is for a boat. Last camshafts where 276/284 made peak power 6800 with head hunters 383ms at 960hp at 10-1 compression. This is ir kinsler injection. Thanks for input. Who would you recommend for grinding camshafts. Thanks.
Any of them are good. I had Kirk Milner do a cam for me, works. Chris Padget is good too. Seems they have some issues with getting a hold of then at times.
.937 lifter, big wheel, big base circle
Mike Jones
he can make the core too
his inverse flank profiles cannot be beat
Discussion Starter #10
Only cam grinder I could find that could do it was crane. Know body had a core that they could get what I needed out of it.
Crane has been good to me and their top solid roller cam arrives in Less than a week for $340
Whatever you do, stay away from induction hardened cores if it’s a solid roller.
1 - 11 of 11 Posts
