1 - 11 of 11 Posts
ls1 s/s notch on 28s
Im looking for some to do my radiator system an all i can find is -12 or -20 really..i found some one summit but its only sold in 3ft or 6ft lengths and i need like 4.5' of it at the most.
thanks
and a little bent
If that doesn't work out for you the speed shop at Atco sells it by the foot, and more then likely has all the fittings you would need. This Sat is the 10.5 race and 8.50 index, maybe one of your buds could grab it for you.
Discussion Starter · #11 ·
alright anyone think i should go to -20 instead though seeing this car will get some street use right now till the real motor gets put in her..i know -16 is .875 inside dia and -20 is 1.125 for inside dia..
1 - 11 of 11 Posts
