1 - 20 of 112 Posts
HIRED GUN!!!
Cool will be nice to see you again Duck...Hope to make your race...And will if Motor is done and get a few test hits a week or two before the race.
Either way ill see you soon and your buying dinner:cool:
ricky we gotta go to his race whether motor is ready or not me and yo wife already made plans haha i cant wait for fat weekend talked to rob valden tryed to get him to talk to frankie taylor
HIRED GUN!!!
Discussion Starter #16
Fat Tuesday xtreme 275 Rules.....After Talking with 20 different racers, this is what I come up with....
FORMAT:
This is an 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. X275 is a qualified quick 16 field. Courtesy staging and autostart is in effect. There will also be another class called
BODY:
The car must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass replacement panels are limited to hood, front fenders, doors, decklids, and bumpers only. All front ends must be of factory dimensions and cannot be stretched. Aftermarket wings and spoilers are permitted. Complete stock appearing front and rear bumpers are required. A hood must cover the entire induction system. Forward facing hood scoops/ turbo or supercharger inlets are permitted.
INTERIOR:
Factory appearing dashboard, door panels, and driver seat is required. Full Carpet is required on floorboards. Factory floor pan on driver and passenger side required. Bare inside frame of car cannot be exposed. Aftermarket steering column is permitted.
WINDSHIELD/WINDOWS:
OEM glass or lexan windows are permitted.
CHASSIS:
Complete stock chassis and frame rails must be retained. Back-halved cars are not permitted. Front core support may be modified or removed. Aftermarket bolt-on replacement front K-members/sub frames are allowed (if front shocks bolt to K-member then they must be in factory location). Mini tubs are allowed. Rear frame rails may be notched for clearance. Factory wheelbase must be maintained.
ENGINE:
Maximum displacement for all engines is 632ci. Maximum displacement for Nitrous engines is 632 ci. Small blocks are allowed any deck height. GM Big Blocks are limited to a 10.2 deck height. Ford Big Blocks are limited to a 10.3 deck height. Mopar Big Blocks are limited to a 10.7 deck height.
TURBOCHARGERS
Single turbocharger limited to 88 mm maximum. (GT55-88, Pro-Mod 88, ET-R88 or = mid/large frame turbo). Turbocharger size will be verified by measuring the housing bore at the leading edge of the impeller wheel and must maintain the contour of the compressor housing. The maximum diameter of the housing bore at the leading edge of the wheel may not exceed 2 mm more than the maximum allowable turbocharger size permitted. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type of air to air or water to air intercooler permitted. Turbochargers w/nitrous oxide are prohibited except on 2-rotor, 4 cylinder, and inline 6 cylinder engines.
SUPERCHARGERS:
Cog or gear driven superchargers are permitted, must meet all factory inlet, outlet, and internal housing dimensions. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type intercooler is permitted. Cannot combine with nitrous oxide. Roots superchargers are limited to a 10-71. Centrifugal superchargers are permitted. Screw superchargers are not permitted. From List of Superchargers below.
NITROUS OXIDE:
Big Chief Heads Limited to 1 Carb and 2 Nitrous Kits(No Sheetmetal Intakes). Conventional Head Big Blocks and Small Blocks Permitted to run any type multi-stage nitrous systems, Sheetmetal Intakes and multiple carbs.
TRANSMISSION:
Any factory style automatic transmission allowed. Bruno-Lenco transmissions are prohibited. Clutchless manual transmission and clutch assisted manual transmissions are permitted on naturally aspirated combinations only. Electric shifters or air shifters are permitted.
INDUCTION:
Small Block combinations may run any type induction. Big Block combinations are limited to a dedicated single carburetor with cast intake.
OILING SYSTEM:
Dry sumps are permitted on all cars.
EXHAUST:
Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders but must not affect timing or staging beams.
FUEL:
Gasoline only is permitted. Alcohol or E-85 or other derivatives is prohibited.
STREET EQUIPMENT:
Functional headlights, taillights and brake lights required. All headlights, brake lights, marker lights, etc must be on car and not removed for any reason. All vehicles may be towed back from their passes.
SUSPENSION:
Stock style suspension cars only (See weights below for penalty for aftermarket suspension). Four links are prohibited on all cars. Aftermarket direct replacement components such as: front control arms, rear control arms, front coil over shocks, and rear coil over shocks are permitted. Aftermarket rack and pinion steering allowed. Rear leaf springs, springs, shocks, and coil-overs may be moved to accommodate tire clearance, and do not need to be mounted in stock location. Bolt-on or welded sub-frame connectors, rear sway bars, are permitted on all cars. Wheelie bars are prohibited on all cars. Torque arms are only permitted on cars that were originally equipped from factory with it.
TIRES:
All cars with power adder must compete on a Drag Radial type tire with the following sidewall designation 275/60/15. Naturally aspirated cars are permitted to run a 28.0” x 10.5” slick, no “W” tires permitted.
Minimum base Weights:
All minimum weights include the driver.
Naturally Aspirated (small block) 2500 lbs
Naturally Aspirated (big block with standard deck height and conventional head) 2800 lbs
Naturally Aspirated (big block with tall deck height and conventional head) 2850 lbs
Naturally Aspirated (big block with standard height and big chief head) 2950 lbs
Nitrous (small block) 2750 lbs
Nitrous (big block with standard deck height and conventional head) 3150 lbs
Nitrous (big block with tall deck height and conventional head) 3250 lbs.
Nitrous (big block with tall deck height and big chief heads) 3350 lbs
Single YSI / F1A/6-71 Supercharger (small block) 3000 lbs
Single F1C/8-71 Supercharger (small block) 3100 lbs
Single F1R / Xi/10-71 Supercharger (small block) 3200 lbs
Single 76mm T6 Turbocharger (small block) 2900 lbs.
Single 80mm T6 Turbocharger (small block) 3000 lbs.
Single 85mm T6 Turbocharger (small block) 3050 lbs.
Single 88mm T6 Turbocharger (Y2K or GT47-88 ) (small block) 3100 lbs
Single 88mm T6 Turbocharger (GT55-88, Pro Mod 88, ET-R 88 or =) (small block) 3200 lbs
* Small Blocks with single stage nitrous system: deduct 50 lbs
* Small Blocks (NOS only) with 23 degree Chevy heads, 20 degree Ford heads, and 18 degree Mopar heads: deduct 100 lbs.
* Small Block (NOS only) non-inline valve head with more than 2 nitrous kits: add 100 lbs
* Non-Intercooled boosted cars: deduct 50 lbs.
* Aftermarket rear suspension (Ladder bar): add 50 lbs.
* Buick/Olds/Pontiac Nitrous combos will be 3250 and not exceed 588 cu inches
* V-6 Turbocharged/Supercharged/Nitrous combos will deduct 200 lbs from base weight
Pro Photo Productions once again plains on being at the 15th Annual 2011 Fat Tuesday Blowout at Hub City Dragway doing both photos and event videos!
Ricky when you get a chance give me a call at 940.393.3167!!!
HIRED GUN!!!
Discussion Starter #20
Mistake in the rules proof reading was poor Sorry..
FORMAT:
BODY:
INTERIOR:
WINDSHIELD/WINDOWS:
CHASSIS:
ENGINE:
TURBOCHARGERS
SUPERCHARGERS:
NITROUS OXIDE:
Big Chief Headed and Conventional Headed Big Block Limited to 1 Carb and 2 Nitrous Kits(No Sheetmetal Intakes). Small Blocks Permitted to run any type multi-stage nitrous systems, Sheetmetal Intakes and multiple carbs.
TRANSMISSION:
INDUCTION:
OILING SYSTEM:
EXHAUST:
FUEL:
STREET EQUIPMENT:
SUSPENSION:
TIRES:
Nitrous (small block) 2850 lbs
Nitrous (big block with standard deck height and conventional head) 3200 lbs
* Buick/Olds/Pontiac Nitrous combos will be 3350 and not exceed 632 cu inches
1 - 20 of 112 Posts
