1 - 6 of 6 Posts
The pistons are not the same. The angle that the valve pocket is cut would be different . If you all ready have 18 deg pistons you might be able to have them fly cut to correct this problem if there's enough material there . as for the shaft rocker system i would go with T&D
Depending on the head the rockes stands and rockers should work
Jesel stuff interchanges pretty good.
Drunk and Disorderly
Nothing against Jessel, but my T&D setup is awsome.
1 - 6 of 6 Posts
