1 - 3 of 3 Posts
All motor wannabe
Please Contact Alex Hays at 7349266067 if you're a serious potential buyer, no tires kickers if you low ball me Ill tell you to go eat a dick
$35000 obo will throw in a new block at $35000
Motor will need a Hone, a set of .937 key way lifters and pistons to match current bore in the block, or use the new pistons in your block/new block and hone your block to fit them. I can get you a new big M block and used or new lifters if buyer would like.
It is currently disassembled and at Mid South Racing Engines in Tennessee. Will be picking it all up still disassembled in the next few weeks. Or Buyer can pay to have it assembled by Ian Landies at Mid South Racing Engines.
Motor was originally built and upgraded several times by Uratchko Racing Engines. Conventional headed 588” BBC has been 4.693 @ 153.81 @2905lbs (efi), 4.697 @ 151.65 @ 2915lbs (efi) and 4.691 @ 144 @2850lbs (carb) All passes made on a 275 drag radial. Current world record holding engine for an Naturally Aspirated drag radial combo. Would make a stellar nitrous combo with a different pistons design.
Motor was never on an engine dyno after EFI swap but estimated to make 1420 to 1440 at the crank based off ET and weights ran at various track and various conditions. It was put on a chassis dyno with 2 pulls to 9000 made 1180 rwhp at 9000rpm with a 8300rpm loose stall converter. With a 2.800” carb and before cam changes the motor made 1395hp and 926 ft lbs on the first pull to 8500 rpm on bob book racing engines dyno; before dyno had issues and we were not able to run it to max rpm motor peaks at 9000.
Block:
Dart Big M 9.8” deck 4 bolt main
Bore 4.652
Bushed for .937 keyway lifters
55mm roller bearings
Custom oiling mods in valley
Screens on oil returns
Setup for Dry sump oiling currently
Fresh Line bore with new main caps in 2017
Will need to be Honed
Setup with engine plate and mid plate
Setup for remote water pump
Heads:
Slick Rick SR20 heads New 2018. These heads are considered to be the highest flowing and quickest set of conventional heads out there at the moment per rick him self, hundreds of hours of R&D went into them. Custom hand porting with extensive work done.
Intake and exhaust valves will be disclosed privately.
Have flow sheets that will be disclosed to serious buyers
Just Freshened with all new components February 2019
Jesel Custom built rocker system (Big $) Billet steel rockers shaft mounted rockers
1PC billet rocker stand
Multiple custom cut 1pc stand shims for different cam lifts to keep geometry correct
New Custom PSI springs with extras (Can get them without issues have part number)
New never ran Victory Titanium valves.
Fresh Valve job
Titanium retainers
Steel keepers
New seals
O-Ringed exhaust ports (no gaskets or RTV needed)
Oil drain backs in heads with lines to pan.
Valve Covers:
Billet SR20 valve covers with o ring, passenger side has fitting for vac pump hose.
Uratchko Racing Engines engraved in top of valve covers can be machined out.
Stainless bolts, valve covers designed to clear rocker system
Intake: Billet Marcella Manifolds single plane manifold custom built for heads Billet bottom and top.
Can be ran with carb if wanted. Currently setup for EFI but no changes were made minus bungs when EFI swap was done. Water fittings included. Setup for dry sump valley scavenge in rear and vac sensor.
Dual map sensor fittings in rear of intake can be used for Map and air temp (currently setup like that)
Custom adapter for top for either carb or EFI Throttle body. -12AN fuel rails for big fuel.
Throttle Body: Visner/Holley Big Oval Throttle body, fits 4500 flange and bolt pattern. Flows 2550 CFM
4 EFI Injectors with rails and lines setup to spray fuel under blades to cool aircharge (worth big power on dyno and ET on track)
Fuel Injectors:
120lb/hr Bosch Motorsport injectors in runners
19lb Bosch Motorsports injectors in throttle body.
Have a set of 8, 160lb/hr Billet atomizer injectors just gone through and rebuilt by Jack French at atomizer.
Wanted to try them never had the chance to back to back them. Figured spray pattern is worth power.
Crank:
New Winberg Billet Crank 4.350 stroke June 2017
Standard main standard rod journals
2.100 rod journals SBC
Knife edged
Cross drilled
All the works minus polishing
Rods:
Billet Steel Carrilo Rods brand new April 2019
New design to correct a design flaw in previous rods.
Pistons:
Brand new May 2019 CP pistons extremely thin prostock/NA ring package
Just shipped May 1st, 2019
Custom Pins for rod and pistons
Pushrods:
Trend Top alcohol pushrods with self lubing tip
Lifters:
Will need a new set of .937 keyway lifters sold previous set was going be putting a large wheel guided lifter in but never got around to it.
Front Drive:
Jesel Belt Drive with new drive cover never installed
Cam:
Custom 55mm grind by Bullet, specs from Uratchko Racing Engines
Have Cam Doctor Data and Spintron data on cam. Specs will be given to buyer.
Never reground.
Oil Pan: Moroso 4 stage dry sump pan with big kick out, sectioned scavenges with screens on all fittings. Oil Returns from heads to pan
Oil Pump: Daily Engineering 6 stage “prostock” pump with HTD pulleys, Big Money pump (numerous different pressure springs included” Custom no collapse oil lines on all scavenge lines. Valley scavenge and 4 scavenge lines in pan.
-20 out let to dry sump tank
Oil Tank and Filter:
Stefs custom aluminum dry sump tank with connected over flow and breather. System takes around 8 qts (0-5 or 0-20 oil. Have several cases of 0-20 LAT racing oil to go with motor)
Billet filter housing using chevy style filters, always ran Wix or K&N filters
Balancer and Crank Drive:
ATI balancer
Peterson Spline Drive system setup to run oil pump at proper speed for engine rpm.
Vac Pump:
Moroso 4 vane enhanced design vac pump: System pulls 22-24” mmHg depending on weather conditions Hose to valve cover. Moroso puke tank with breather included.
Electronics:
Motor is setup currently for Holley EFI.
Has Holley cam sensor
Holley crank sensor using MSD flying magnet crank trigger wheel.
Set up for Coil Near Plug ignition system
Will give Buyer all tunes. Will also sell Buyer all EFI components needed at Dealer cost (keeping the current efi system with the car for now)
Headers: Will include with entire motor. Fit fox Mustang with outlaw k member and turbo 400 may fit other combos as well.
Custom Built stainless 4-1 under car headers Built by Calvin Elston at Elston Exhaust in Mathew, NC (Guy that invented the Tri Y header for nascar) 10 total 02 bungs, 1 in each primary and one in each collector. Ran 10 02s on the car to get air fuel perfect in each cylinder.
Extras: Several flex plates including a brand new never ran Billet aluminum Reactor flex plate.
2 Big block Chevy mini starters to fit exhaust and oil pan.
2 Custom Built Air pans for MCS cowl hoods (worth over a tenth of a second in the ¼ mile vs no pan) Built by skinny kid Racecars. Will include if buyer purchases whole setup.
87-93 mustang MCS 4” fiberglass cowl hood with dzuz fasteners installed for billet rails, hood cut for hood scoop, painted custom blend of calypso green. Hairy Glass Prostock big D hood scoop with mounts to go to motor plate, custom air pan in scoop to fit Visner throttle Body, (Air inlet temp sensor mounted in rear of pan). Painted Tuxedo Black. $1200 for hood and scoop see pictures of hood on car below.
Billet 8” Bolt Together Neal Chance Converter with Titanium bolts, 5 billet stators built and ran with combo have data on all of them. Spare o rings, bearings and shims $5500
Rossler Built turbo 400, stock case with Clean Neutral, lightened billet aluminum drums and internals, Custom Coan gear sets 1.66, 1.31. 1.0 and 1.60, 1.22, 1.0 ratios available, roller tail shaft, moroso sheetmetal pan with drains/temp sensor ports. Lokar Dipstick, SFI Ultra Bellhousing for chevy. Low pressure pump for reduced drag. Trans was just gone through. Coan Billet forward manual Valve body with clean neutral, Coan Billet quickrelease trans brake with single wire setup. Looped lines. Never got above 140 pan temps even after multiple rounds with little turn around. $6500
Will sell Trans and converter/stators together for $11000
Fuel Pump: Weldon 2345a Bought brand new in Feb 2019 has only 9 runs on it $850
Videos of it running
https://youtu.be/BW61n_xVx10?t=161
1 - 3 of 3 Posts
