Can you test this same theory using a more common style Blankenship combination with a 4 inch to 4.100 stroke at a good avg rpm for the given topic.
This is 4 x 4, and I adjusted the VE were it makes around 1300hp just to show that it takes about the same cfm to make the hp.
402.125 Cubic Inches @ 11000 RPM with xxx.00 % Volumetric Efficiency PerCent
Required Intake Flow between 499.8 CFM and 531.9 CFM at 28 Inches
Required Exhaust Flow between 306.9 CFM and 357.7 CFM at 28 Inches
600 RPM/Sec Dyno Test Lowest Low Average Best
Peak HorsePower 1204.6 1254.2 1279.0 1303.7
Peak Torque Lbs-Ft 628.9 654.7 667.7 680.6
HorsePower per CID 2.996 3.119 3.180 3.242
Torque per Cubic Inch 1.564 1.628 1.660 1.693
BMEP in psi 235.8 245.5 250.4 255.2
Carb CFM at 1.5 in Hg. 1497 1666 1750 1835
Target EGT= 1086 degrees F at end of 4 second 600 RPM/Sec Dyno accel. test
Octane (R+M)/2 Method = 116.0 to 117.0 Octane required range
Air Standard Efficiency = 67.55653 % for 16.000:1 Compression Ratio
Peak HorsePower calculated from Cylinder Head Flow CFM only
600 RPM/Sec Dyno Test Lowest Average Best Potential
Head Flow Peak HP = 1113.4 1196.5 1279.6
