typical 12bolt,4.10 pro gear ,spool and billit moser yoke,solid spacer(no crush sleeve)..no slack anywhere,gears are not worn and check great..car will leave a puddle after it sits a few weeks and its from the middle of the yoke where the nut is...i fill the rear till it runs out the side factory weep hole,just like i have done every car i have ever owned..i run a real thick oil so that aint it...i have heard some people put silicone on the threads and washer to seal it up...what is the correct way to do it?
