1 - 9 of 9 Posts
My ports on my heads have been opened to a 1262R gasket but the water port opening is to big , i need the opening to be the shape like a 1262 gasket, any idea what part # that is
I don't get it. Doesn't the 1262R gasket still contact both the head and the intake faces around the water port?
Not on my heads, the water port opening on the gasket is bigger then water port on my heads
I don't think you understood my question.
Even if the 1262R gasket opening is LARGER then your head water port opening, it should still contact the both the intake and cylinder surface around the perimeter of the gasket. It doesn't matter if there is a void, as long as the gasket has solid on both sides to seal. I use a trick flow gasket that is similar and it works just fine.
1 - 9 of 9 Posts
