You'll be fine... High 7's / 5.0s~1500hp on gas on a low base press
Thanks its my first go at efi just worried about not being able to idle cleanNo reason not to order 160's if you plan on expanding in the future I ordered 120's and less than 2 months later ordered 160's the initial cost isn't different enough to short change your self in my opinion.
You sure you aren't out of pump. I went 8.9 @ 153 @ 3850# @ 89-91% IDC on the Holley 120's on e85. That's about 1000 rwhp.Mine were struggling a little north of 800whp on e85
+1. Idle at 900 rpm @ 14.5:1 AFR on pump gasWhat EFI system?
Holley 160's have no issues with clean idle...
I've put them in several cars with zero issues at idle.
what base pressure?You sure you aren't out of pump. I went 8.9 @ 153 @ 3850# @ 89-91% IDC on the Holley 120's on e85. That's about 1000 rwhp.
Lol so 8-120s at 90% with a bsfc of .6 gives u 950fly? Lolz oklwhat base pressure?
90% IDC on 120lb injectors with a base of 43psi on e85 is only about 950 at the crank
160's would put you around 1250 at the crank with a base of 43psi
and that is all assuming you are actually very efficient with a BSFC of 0.6
I
No shit and u are way the fuck offdo the math... fuel Flow dictates power....
its a very simple math calculation to figure out potential maximum power to be made
physics doesnt lie.
I assuming bsfc around .6 based on efficient forced induction....and then the extra 30 % ish fuel you use on e85You are the one that said .6 not me....
.6 is a ballpark gasoline bsfc..
I see e85 run from .8-85
With a .85 bsfc for typical e85 it is 1015hp
