1 - 3 of 3 Posts
iF you can get your ride height right with the threaded spanner nuts on the rear shock will a 12'' 130 # spring perform any differently as a 14'' 130# spring? does the longer spring have more stored energy?
no it takes the same energy to move it one inch 130 but a longer spring could be a lighter weight and as long as it does not go into coil bind have more energy at the same compressed height
1 - 3 of 3 Posts
