Before removing the nut..does it have a solid spacer or a crush collar. If solid spacer remove nut and then torque to spec. If a collar be sure to mark the nut and tighten back to the same spot.
Polish yoke, replace seal and check old seal to see if spring popped off if it had one. Silicon washer/nut.
