1 - 3 of 3 Posts
· Registered
All I have is some 10wt engine oil in the shop and I was wondering if it makes that much of a difference on the torque specs from 30 wt engine oil????
Also I have Crower severe duty shaft mounted roller rockers, that I'm mounting on Brodix BBC alum. heads, is 45 lbs too much for the 5/16ths shaft bolts?
Trying to get accurate information. Seems like everyone is different.
Thanx
Mike
· Misanthropist
I only use ARP assembly lube for all critical fasteners.
1 - 3 of 3 Posts
