1 - 12 of 12 Posts
Hey guys,
I can’t seem to find a 10 micron post filter for E85, my 100micron pre- is a stainless mess but my post is a paper and I know the 85 is going to destroy it.
Do they make a replacement element for E85 so I can keep my housing and if not do they offer a 10micron E rated?
Sent from my iPhone using Tapatalk
I'm also using one of the Fuelab <10um units on E85. I've had it for years and years.
Discussion Starter #7
I have a -8 jegs inline filter with a stainless mesh 100micron filter. Anyone know if a aeromotive 10 micron stainless element would work in the jegs housing?
Aeromotive suggested a 40 micron filter for the secondary filter for E85 when I put the system together.
That's what I went with originally on my procharged/EFI 70 challenger, but then the manufacturer of my fuel injectors said no way should I go larger than 10 micron. For a carbbed setup I guess it would be fine.
I picked up a Racetronix filter for my 96 SS project.
https://www.racetronix.biz/product.asp?ic=filter-1010b
I've been running a Fuelab 6 micron for a couple years now with good results. Prior to that I had Fore Innovations SS (10 micron?) which did not filter good enough and ruined a couple of my ID 1300's, ID recommended the Fuelab and I haven't had any trouble since.
https://www.jegs.com/i/Fuelab/083/82833-1/10002/-1
I use cellulose filters but just change them often (1-2 times a season) No worries and not an issue on either car using E85 the last 10 years.
1 - 12 of 12 Posts
