Looking for input on a NA build that I'm starting on. I have a 10.7" KB Olds block with a 4.5" bore. The cylinder heads are Olds DRCE-1's with minimal port/chamber work, and I'm using an early Olds single 4 barrel manifold. The objective is to run low 9.0's- high 8's w/2900lbs big tired, back halved chassis, without having to lean on the motor. I'd like to keep the rpm range low....to in turn keep the maintenance low:smile:
Anyway I'm at the point of deciding what kinda stroke this thing is going to need. With the tall deck height my initial thought would be to go big....4.75"-5.00" but my concern is will the cylinder head/intake manifold support this much displacement? Or would I be smarter to go with less stroke/displacement, keeping in mind that the objective is to build a relatively low rpm piece.
FIRE AWAY.....
FIRE AWAY.....
