1 - 9 of 9 Posts
I have run the MT 29.5 W tire and it is a good tire. I think the limited street true 10.5 tire has come a long way since the last time I tired one. Maybe someone else hase experience with the true 10.5 tire?
I run both of them and if your class doesn't make you run the true 10.5 run the w and you will save yourself alot of headache, alot easier to hook
Tony McKellar
"W" tire is a "no go" in most true 10 inch tire races unless specifically stated they are ok to run.
T/S 368E
Most W's are stiff sidewall, which makes a ton of difference with bigger HP & weight.
1 - 9 of 9 Posts
