1 - 5 of 5 Posts
I have 2 batteries in the trunk of my drag car. They are both connected to a kill switch in the rear panel.of the car. I'm installing a 1 wire alternator and would like to ask to where do I run the cable from the alternator. Do I connect it to the post on the kill switch along with both positive leads? Or, do I connect it to just one battery?
Yes..I know that sounds dumb but either way the electricity will get to both batteries. The real concern is how heavy a gauge cable you run from the alt. to the batteries.
To the side of the switch with the batteries. If you connect it to a battery or the output side of the switch it will keep the electrical system energized
1 - 5 of 5 Posts
