1 - 16 of 16 Posts
I have a dedenbear case Glide with 1.80 straight cut gears. Trans has approx 20 passes on it. I ran a 8.84 (1/4 mile) on Sunday and then the next pass I armed the nitrous (150 shot) and the trans came apart. Car is ~2950lb with me in it. I'm not a tranny guy, but I don't think these gears shouldn't have broke with what I'm putting on them, correct? I just pulled the pan last nite, haven't got the trans out of the car yet.
T/S 368E
Damn, those are usually rated a hell of a lot higher than that. Sorry to see that.
I've also had one of the 2500 HP unbreakable inputs break when a buddy borrowed my trans with a 700 hp street motor.
Looks like I got screwed when I bought the tranny, we got it apart and found stock helical gears in it. :( That explains why they broke I guess. Thanks for everyones input.
Here are the broken pieces, can anyone tell if this is a stock planetary or some sort of aftermarket helical planetary?
Super Rod 2413
They look like stock 1.76 to me. Is the tailshaft soild. You have any picture of that? I just bought a godly 1.80 straight cut gears. I just went threw the same thing last October.
from across the pond...
whoops,that'll be a completely stock 1.76 gear set with a stock shaft and stock reverse annulus...
You've been had...
A set of Hutch's 1.80's with the cryo and iso treatment would work awesome for you...
8.80's? Meyer went 8.0's in his turbo stang, right? Both stock 1.76 sets..wild
Gives me peace to know that going for 9's shouldn't worry me and my 1.76.
Super Rod 2413
how do the godly planets hold up ? how much power have you guys thrown at them and what do your cars weigh? et's ?
My car weights 3350lbs with 750hp and I always double enter. I'll put 20 runs on it in one night. Been running it 2 years now. Foot braking and leaving off the brake. My buddy has the same gear set and has a dragster with 1100hp and he's been running it for I don't know how long. So far so good.
1 - 16 of 16 Posts
