car went 1.333 60 ft. 3.896 330 ft. wht should 1/8 mile et be?
russ369 · Registered Joined Dec 16, 2009 · 44 Posts Discussion Starter • #1 • Oct 8, 2011 car went 1.333 60 ft. 3.896 330 ft. wht should 1/8 mile et be?
drunk stang · Registered Joined Feb 20, 2008 · 1,919 Posts #2 • Oct 8, 2011 (Edited) depending on combo.... blower, N/A, turbo.... I would say around 5.60's
russ369 · Registered Joined Dec 16, 2009 · 44 Posts Discussion Starter • #3 • Oct 8, 2011 nos spraying around 300
Blade · Security jus sayin crew Joined Nov 29, 2009 · 50,209 Posts #4 • Oct 8, 2011 last night we went a 5.93 in the 1/8th with a 1.32 60ft.
Blade · Security jus sayin crew Joined Nov 29, 2009 · 50,209 Posts #6 • Oct 8, 2011 russ369 said: what mph Click to expand... its around 120 i think. at the 1/4 we were at 147.
farrigno · aka hulk Joined Aug 19, 2006 · 4,965 Posts #7 • Oct 8, 2011 thats around a 5.90-et,depending on a lot of variables,...like was the nos used right out of the gate?,ect,ect...
D Dustin Morgan · Registered Joined Mar 14, 2009 · 4,149 Posts #8 • Oct 8, 2011 I have been 1.329 3.830 5.922 117.29 7.734 9.278 145.77 With my car naturally aspirated @ 3725lbs if that helps..
russ369 · Registered Joined Dec 16, 2009 · 44 Posts Discussion Starter • #9 • Oct 8, 2011 175 out of the gate for 7 tens cut off and 300 on
Blade · Security jus sayin crew Joined Nov 29, 2009 · 50,209 Posts #10 • Oct 8, 2011 Dustin Morgan said: I have been 1.329 3.830 5.922 117.29 7.734 9.278 145.77 With my car naturally aspirated @ 3725lbs if that helps.. Click to expand... That is were we are at too.
russ369 · Registered Joined Dec 16, 2009 · 44 Posts Discussion Starter • #11 • Oct 8, 2011 anybody else?
Super_Engine · Registered Joined Oct 30, 2007 · 16,123 Posts #12 • Oct 8, 2011 5.95 - 6.00, seems like everyone is right on the money!
buickbracketrader · Registered Joined Mar 20, 2011 · 285 Posts #13 • Oct 8, 2011 Here's the numbers from my buddy's yellow injected 65 chevelle from Norwalk last year.540 chevy 3400#. 1.330 60 ft 3.847. 330 5.984 1/8 114.64 mph
bigdaddyb1 · Registered Joined Jul 18, 2009 · 829 Posts #14 • Oct 8, 2011 1.303 60' 3.862 330' 5.940 1/8 mile 116.501 2950# foxbody 402Windsor 10.6CR 4.10 gear 275DR Glide and LOOSE footbrake converter 150 shot .15 after WOT ... spun motor to 7100 in 1/8 mile with converter slippage
