1 - 3 of 3 Posts
Is it possible to get a reliable turbo bbc piston to handle around 1500 hp with a compression height of 1.20? I have a 4.125 stroke crower crankshaft, new set of 6.535 oliver rods and the block is a 9.8 deck bbc donovan aluminum block. Doesnt leave much room but will it work and be somewhat reliable or not?
FUCK TONS OF FUN
yes
i have a set on order right now @ JE im guessing they will be on a similar scale to our turbo windsor pistons where everything was just bigger and stronger then a normal custom type piston
Make sure you get a really good pin, shouldn't be a problem though.
1 - 3 of 3 Posts
