1 - 20 of 44 Posts
Going to build a 600-650 [email protected] rpm 454 BBC with hyd roller. 95% street 5% strip.
Icon has two pistons that will fit perfect.
One has 5/64 ringpack
The other 1/16 ringpack
The total price difference in piston/ringpack is almost 200$ will the 1/16” rings be worth the extra 200$ in a build like this?
I think he is saying that the 1/16" piston AND ring package is $200 more than the 5/64" piston and ring package. Doesn't make much sense that just the ring width would result in a $200 difference between packages.
To answer the original question though, 5/64" ring package will work just fine in an engine that will be used 95% on the street. However, OP might consider looking at other brands of pistons for comparison, as there are a lot more ring designs available for the 1/16" rings.
If you're looking to get the most out of your dollar, I'd say well worth the money.
Idiot Savant
Get some Wiseco PTS pistons with the rings and save the money.
The 1/16 will make a little more power and be easier on the bores.
Idiot Savant
First the 5/64ths set. How much do they weigh? Then the set with 1/16ths?
Discussion Starter #10
This
Is Wiseco better than Icon?
5/64
Piston 657+141 pin
1/16
648+141 pin
Look to see what Mahle has to offer, they have some thin street piston/ring packages and along with a good torque plate hone job should be worth some hp and cleaner oil.
Idiot Savant
This
5/64
Piston 657+141 pin
1/16
648+141 pin
They're more consistent. Both will keep the rings off the crank. The Wiseco's come with rings, and they're well priced.
There is, obviously, no advantage in weight. So it's just ring cost that makes the difference. Therefore, run tthe 1/16.
Discussion Starter #16 (Edited)
Will I loose 5 hp with 5/64” vs 1/16”? Or more?
Any other downsides?
More cylinder wear?
This will be my spare engine so will probably see limited use.
200$ is alot for 5hp.
Lets say I use the 200$ on the heads instead to gain 20-30 hp?
You'll never know the difference, get the right compression for the cam and you will be golden.
Why are piston manufacturers even making their slugs with such outdated ring packages?
Even the 1/16 rings seem huge these days.
More cylinder wear?
I can't believe you're still debating this.
Pretty sure those old cast iron rings were hard on cylinders so yes, more wear.
It's going to be way more than 5 hp and how are you going to gain 25-30 hp on the heads with 200.00?
Assembling a short block correctly is time consuming. You only want to do it once. Do it the best you can afford to. It's a lot easier to upgrade the top end down the road if you think you want more power. If $200.00 is a deal breaker on your 600hp engine, you're going about this all wrong.
Scott that's pretty much a mic drop moment. Lol. So I'm just gonna say......"Yeah, What Scott said!". Lol
Pistons are the heart of the build .Never skimp on ring pack or pins.I would never consider either of those ring packs.If I had to sit a yr with no engine to afford better pistons then so be it.You wouldn't paint a house with a wire brush would you?
1 - 20 of 44 Posts
