i have 05 duramax with heater issues.
when driving heater blows hot then cold gauges goes from 210 to 160 and starts blowing cold. upper radiator hose is cold also one side of the heater core is cold. ive changed out both t stats. used the bucket style filler with opening the bleeder on t sat housing after that system worked good while driving didnt over heat. blowing good heat out then i go to park it an let it sit for a couple of hours start it back up and it start all over again good heat then cold but it dont over heat . any ideas?
