Running a 5.4 modular ..Are you gonna run a mod motor or a sbf. The BMR stuff is bad ass
I like the rendering Greg did for you. Is your car getting built already turbomach1? What Rear housing are you going with? Thanks for the info..Using all racecraft stuff with santhuffs
I am gonna build a 434 sbf. Wanna put twin 76mm on it but not to sure yetRunning a 5.4 modular ..
yes the car car is being built at Texas Chassis works. It has a custom 1 off alumn 9 housingI like the rendering Greg did for you. Is your car getting built already turbomach1? What Rear housing are you going with? Thanks for the info..
Looks bad ass. What size of wheel are you gonna run with the rear end cut 2" per side? Thanks for the infoSmart ! the mod stuff gets expensive ! sounds killer ..
I went with the moser m9 rear narrowed 2" per side, with strange internals.
Your car is gonna be killer if it's gonna look like the rendering.yes the car car is being built at Texas Chassis works. It has a custom 1 off alumn 9 housing
I should have the car running by fall.
Josh you going to need a driver for that new setup? I am sure I will be available.Thanks. I can't wait. Were going to pull out all the stops on it. The car should be one of the more advanced Dr/Ls cars out
I wannna run Drag Radial with the car i'm gonna build. Well the X275 class. Cant wait to see the car as you are building it. Keep me posted on your buildThanks. I can't wait. Were going to pull out all the stops on it. The car should be one of the more advanced Dr/Ls cars out
will do. When the chassis work is done and the engine and tubing is ran ill post up pics before the paint shop and stuffI wannna run Drag Radial with the car i'm gonna build. Well the X275 class. Cant wait to see the car as you are building it. Keep me posted on your build
I don't know about driving "I have a year of lost time to make up " but you can defiantly take pics in itJosh you going to need a driver for that new setup? I am sure I will be available.![]()
