anyone ever run into this code. i had it cleared but it came right back on. i cleaned the ground on the frame rail and same thing. i could not clear it. i checked the fuse and that is ok. anyone have a wiring schematic or know were i should test for power. i pulled the module off the pump and ohmed out the pump. pump seems to be ok. i pulled the cover off the module hoping to find a burnt out solder joint but everything looks ok. any help would be great.
