1 - 5 of 5 Posts
i have a 99 f150 with a bad 4.2 i picked up a 4.2 out of an 04 f150, the heads,flywheel,oil pan,intake are the same. according to Hollander the block is different but the mounts are the same, anyone know what the difference is? will it work?
thanks man
whitey
The block casting is different but it does interchange
yep i got the upper and lower intake sets, valve cvr set and rear seal. it only has 68k on it but i sure as heck dont want to have to jack with it after its in.
1 - 5 of 5 Posts
