I have a 2001 mustang with a 5spd.
Only while driving does this happen. Won't do it while out of gear and sitting there even if you rev it up..
What happens is, Say you're coming to a stop at a light and you push the clutch in. The engine will rev to around 2000 rpm and slowly cycle back down to normal idle takes 5 to 10 seconds. You can bump the clutch and bring it back down right away.
I have read on other sites it may be the IAC or the 2nd switch on the clutch pedal. Any Ideas..
The Bullet has the answers I bet.
