1 - 4 of 4 Posts
have an 01 dodge 4x4 with a v10 lost oil pressure. have not done a mechanical gauge yet. but if i need to replace the oil pump where is it and how hard of a job.
Its in the front timing case. Only about 1% chance its bad. 99 times out of 100 the oil sender switch is failing. Birdtracker
Discussion Starter · #4 ·
its a friends truck where do you find the oil sending unit on it im going to try a mechanical gauge this weekend. if its the oil pump how hard is it two change. im used to old fords and chevys not to much on this new stuff
1 - 4 of 4 Posts
