BBF 565 A460 head... what kind of power should I expect? - Yellow Bullet Forums
Old 07-20-2014, 10:47 AM   #1
TJS
Launchin
Default BBF 565 A460 head... what kind of power should I expect?
Just seeing if my ideas match everyone elses...
BES A460 heads 2.400 1.88 titanium valves... heads have some trick stuff done to them.
565, bryant crank, BME 6.800 rods 13:1
60mm cam high 280 intake duration, high 300 exhaust duration on a 118 .950/.917 .937 keyed lifters
1/2 exhaust pushrods 7/16 taper intakes
external wet sump pump , star vacuum pump.
cast single plane intake maxed out... dominator carb
its a nitrous engine
TJ Strange
Always looking at data
TJS is offline   Reply With Quote
Old 07-20-2014, 10:55 AM   #2
cboggs
cboggs's Avatar
Default Re: BBF 565 A460 head... what kind of power should I expect?
depends on who's dyno as to what "number" you get.
could just search the internet for the biggest numbers and use THAT dyno.
Kidding aside, ... any idea what the cross section of
the head is?, ,, I'd guess 1070 ish, ..
Curtis
Race Flow Development
http://www.raceflowdevelopment.com
757-222-9717
WD- Brodix-Dart-Edelbrock
cboggs is offline   Reply With Quote
Old 07-20-2014, 11:31 AM   #3
738drvr
738drvr's Avatar
Over 1000hp easy. 2 guns and you could get to 2000.
738drvr is offline   Reply With Quote
Old 07-20-2014, 11:31 AM   #4
calypso50kid
All motor wannabe
calypso50kid's Avatar
Wayde Mahoney had a 577 a head motor. I believe he was making over 1200 with it was built for all motor
former racer, now i just support those who crave the need for speed
Hays Consulting Racepak, Holley, MSD, Earls Dealer and more.
Contact me at 7349266067 or email at [EMAIL="[email protected]"]
Thanks to
Efi University
PSI Springs
Holley EFI
Racepak Data Systems
calypso50kid is offline   Reply With Quote
Old 07-20-2014, 01:22 PM   #5
scj70
nice,...
scj70 is offline   Reply With Quote
Old 07-20-2014, 01:58 PM   #6
BBF612
BBF612's Avatar
Just googled A460 heads BBF and found this for sale in 2011.
BBF 555ci [/b]
- IDT Premier block
-Bryant light weight billet crank
-GRP 2000 pro series aluminum rods
-King main and rod bearings
-Ross digitize pistons and CNC domes
-Moroso custom aluminum oil pan
-Trickflow A-460 heads with custom titanium valves,alloy seats,psi valve springs,mainly titanium retainers,hardened locks
-Trickflow A-460 4500 intake
- Jesel custom rocker arms
- Jesel front drive kit with distributer
- roller cam bearings
- Comp cams custom grind solid roller cam-shaft
- Isky BBF .904 roller lifters
- Total seal custom piston rings
- BHJ lifter bore bushing's
- ATI balancer
- Danny bee thrust plate with double torrington bearing's
- Mainly 7/16 push rods
- 4 stage moroso dry sump system
- Moroso dry sump tank
- Moroso 4 vane vacume pump
- Meziere BBF water pump
- MSD flying magnet crank trigger
- BES sheet metal valve covers
- Dale cubic CFM 4500 carb with cnc spacer
This brand new setup only has 35 passes and just won the candian nationals runs consistantly 8.20's has been 8.22 @169.87 mph has been 174.66 mph on a 29.5 tire @3270 pounds.
we stopped making dyno pulls at 1261hp at 900 foot pounds of torque, fastest et at 3270 pounds 8.22 and holds the mph record at 175 dyno sheets will be giving to the new owner of the engine.
http://www.460ford.com/forum/showthr...=152519&page=3
BBF612 is offline   Reply With Quote
Old 07-20-2014, 02:43 PM   #7
calypso50kid
All motor wannabe
Quote:
BBF 555ci [/b]
- IDT Premier block
- ATI balancer
Ok that's the motor in was thinking of that wayde had. The 577 was a bbc conventional
Thanks to
Efi University
PSI Springs
Holley EFI
Old 07-20-2014, 05:10 PM   #8
BBF612
BBF612's Avatar
It's amazing how the stars aline, I have no clue who he is, but his cars performance and national win backs up his dyno claims I would think.
Old 07-20-2014, 06:58 PM   #9
crumple
crumple's Avatar
Wayde at Milan.
crumple is offline   Reply With Quote
Old 07-20-2014, 08:17 PM   #10
scj70
Is this the engine forsale?..
Quote:
Originally Posted by crumple View Post
Wayde at Milan.
Old 07-20-2014, 10:17 PM   #11
68FormalGT
Wayde at Milan.
Who makes that intake?
68FormalGT is offline   Reply With Quote
Old 07-21-2014, 11:45 AM   #12
killer puller
Launchin
killer puller's Avatar
I made 1200 HP on a 532 with sheetmetal intake and twin carbs on Q-16. People questioned the dyno validity and the data is questionable. The engine is in a pulling truck and we have a 640 ci C headed engine in another truck that dynoed 1200 HP on another dyno. The 532 has yet to loose to the 640. I see 1200HP as a realistic target with your i, s dotted and t, s crossed. Camshaft and intake are critical.
killer puller is offline   Reply With Quote
Old 07-21-2014, 12:27 PM   #13
clutch assisted
Quote:
I could be wrong, but that intake looks custom built. Not sure if BES does that stuff in house or not, but guys like Gaby Labiosa build intakes like that.
clutch assisted is offline   Reply With Quote
Old 07-21-2014, 02:32 PM   #14
68FormalGT
Quote:
Looks cast but the top is different then a single T/R trick flow top
Old 07-21-2014, 02:40 PM   #15
1windsor1
1windsor1's Avatar
Garage
Don't quote me, but I'm pretty sure that's an A460 tunnel ram that BES modded into a single 4.
I'd also bet you'd be around 1150 or so with the right cam, possibly more if you're close to either Kentucky or Georgia.
1windsor1 is offline   Reply With Quote
