495ci LSX 99 ss camaro - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > GM Builds
GM Builds Share all GM builds in this section.
Old 05-04-2014, 12:54 PM   #1
turbosb2
turbosb2's Avatar
Default 495ci LSX 99 ss camaro
Well guys ive posted my combo on the LS section and N/A power section now Im here. I picked up a real clean x grudge ss camaro last year as a roller. This car is real clean and has low miles on it and its a real ss . It used to run a 416 inch LS3 on the hose and used to run low 9,s high 8s. This car was very well known at milan drag way . The plans were to put together a truck block 6.0 and run a turbo on it, its a proven 1000+hp combo .But after seeing basically every thing Fbody go through the burnout box for the last 5 years with turbos on them I thought I would change (NO offense turbo guys) The plans were to get a lsx tall deck and cram the biggest stroke crank in it that I could find and then stuff a 4.250 bore piston in it (506 ci) . And then spray the shit out of it after that. After going over the build with my engine builder he tells me that N/A combo would be fine and that should throw down low 8 second passes as long as i could get the car under 2800lbs.But it wouldn't be good for a spray motor cause of the lack of gasket in between the cylinders so we dropped the bore size down to 4.185 and 4.5 inch stroke (495ci). The motor i have now is a 13.5 to 1 lsx . LSX tall deck, callies 4.5 inch stroke crank, k1tech billet rods, race tech 4.185 nos pistons, CBM LSX LS7 HEADS flow over 400 @750, fully ported holley hi ram , 2 1050 ultra dominators, comp solid roller with over .800, total seal ap rings ,king,ati,arp,msd, etc......then a Nos 2 stage fogger 300 and 300. 6 total. The car has all the good stuff 40 spline 9 inch all the good components up front and back. My plans are to minitub the car and do a full moly cage and get a bigger tire under it. I will post more pics of the chassie build. This car should be done in a few months , should have already been done.
99 SS Camaro with a Little LS7 SBC.. 4.155 bore x4.500..RHS..Tall Deck...Callies Ultra and Magnum....Billy Briggs racing engines built shortblock..(248-669-5810)..Mast Intake AED 1350 DominatorůMartin Smallwood for a big roller cam(Diamond NOS pistons from [email protected] Vincent performance-270-977-1893)Headwinds..LSX LS7 Heads [email protected] stages Holley HP EFI
turbosb2 is offline   Reply With Quote
Old 05-04-2014, 12:55 PM   #2
turbosb2
turbosb2's Avatar
Default Re: 495ci LSX 99 ss camaro
[IMG][/IMG]
Old 05-04-2014, 12:56 PM   #3
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:57 PM   #4
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:57 PM   #5
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:58 PM   #6
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:58 PM   #7
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:59 PM   #8
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 12:59 PM   #9
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 01:00 PM   #10
turbosb2
turbosb2's Avatar
More pics to come
Old 05-04-2014, 01:05 PM   #11
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 01:07 PM   #12
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 01:14 PM   #13
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 01:27 PM   #14
turbosb2
turbosb2's Avatar
[IMG][/IMG]
Old 05-04-2014, 01:29 PM   #15
turbosb2
turbosb2's Avatar
This car used to drag the bumper on anything over a 225 shot .
