Holley and cut off switch - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 05-01-2014, 09:33 PM   #1
Faulty81
FFW crew
Default Holley and cut off switch
Holley says TO THE BATTERY, but what if you're running a Cut off switch? Are there any problems running it to the cut off?
Faulty81 is offline   Reply With Quote
Old 05-01-2014, 09:42 PM   #2
Doug F
Default Re: Holley and cut off switch
To the battery for the main power and ground. The switched power and injectors and ignition should all be cut off by the switch however.
Doug F is offline   Reply With Quote
Old 05-02-2014, 09:49 AM   #3
Faulty81
FFW crew
Thanks Doug
Old 05-04-2014, 03:11 PM   #4
skeletonpsycho
skeletonpsycho's Avatar
I put the power wire to the car side of kill switch and the ground directly to bat.
SKELETONPSYCHO STREETCAR MAFIA IS IN FULL AFFECT!!!
YOUR PARTNER IN MAYHEM TROY
www.RACEWires.com
high performance vehicle wiring
https://www.facebook.com/RACEWires
skeletonpsycho is offline   Reply With Quote
Old 05-04-2014, 05:39 PM   #5
Brillko
Member
Pullin gears
Quote:
Is the kill switch only for ECU Power?
http://www.brillko.com
Brillko Engineering
Brillko is offline   Reply With Quote
Old 05-04-2014, 06:37 PM   #6
highpockets
Pre-Staged
If you were to wire it to the cutoff side,would it be necessary to perform the TPS learn when power was cut ? Not really wanting to dick with my car in the tech lanes,would be easier to kill power to ign switch/fuel pump and wire master power to ECU direct. Thought ?
highpockets is offline   Reply With Quote
Old 05-04-2014, 06:39 PM   #7
SuperStang90
Spooled up
SuperStang90's Avatar
There is a main power harness that goes directly to the battery. There are a few loose wires in the main harness, the red one powers the injectors and fuel pump, which should be ran to the car side of the cut-off switch.
90 Mustang GT
SuperStang90 is offline   Reply With Quote
Old 05-04-2014, 06:47 PM   #8
highpockets
Pre-Staged
Quote:
Thats kinda the way I am thinking. The tech guys around here like to verify our shutoffs actually work and the alternator wont keep things going,I just dont want to screw up the tune or reset the ECU each time.
Old 05-04-2014, 06:50 PM   #9
Danny Cabral
Danny Cabral's Avatar
Quote:
Originally Posted by highpockets View Post
If you were to wire it to the cutoff side, would it be necessary to perform the TPS learn when power was cut?
No, the TPS AutoSet is stored in the ECU. Wire it as instructed in post #2.
May God's Grace Bless You
New Holley Dominator ECU for sale every month. (Email me for my usual low price: d c f 1 5 0 @ c o m c a s t . n e t)
Danny Cabral is offline   Reply With Quote
Old 05-04-2014, 07:48 PM   #10
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
If you have EFI and an electric fuel pump it is sooooooo easy to wire this correctly! The alternator will not keep the engine running, just use a disconnect switch with two sets of contacts. Large set for the main power disconnect, small set to kill the electric fuel pump relay (can also ground the points input of the typical CD type of box.)
I wish we could make a sticky in this section to explain how to do this. Seems like once a month I type the same thing over and over and over................
Mike Beck is offline   Reply With Quote
Old 05-05-2014, 04:21 AM   #11
Danny Cabral
Quote:
Originally Posted by Mike Beck View Post
That's kinda the way I am thinking. The tech guys around here like to verify our shutoffs actually work and the alternator won't keep things going. I just don't want to screw up the tune or reset the ECU each time.
If you have EFI and an electric fuel pump, it's sooooooo easy to wire this correctly! The alternator will not keep the engine running, just use a disconnect switch with two sets of contacts. Large set for the main power disconnect, small set to kill the electric fuel pump relay (can also ground the points input of the typical CD type of box.)
A conventional cut-off switch works fine.
The Holley 558-308 Main Power Harness should be wired directly to the battery terminals.
The switched red/white wire should be wired the the ignition key, then to the cut-off switch.
The 14 AWG red wire (system relay) should be wired to the cut-off switch.
When turning off the rear cut-off switch, the engine dies, no matter what.
Old 05-05-2014, 05:54 AM   #12
Danny Cabral
Just use a disconnect switch with two sets of contacts. Large set for the main power disconnect, small set to kill the electric fuel pump relay...
Quote:
On second thought, your dual contact cut-off switch is a cleaner way of doing it.
It may cost more, but there won't be large and small gauge wires under one terminal.
Old 05-05-2014, 10:09 AM   #13
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
The dual-pole switch makes things so darn easy.
Old 05-06-2014, 01:09 AM   #14
S2H
S2H's Avatar
Garage
per NHRA Rules it has to be to the cut off switch...not directly to the battery...
I have run mine to the cut of switch for a few years with no issues.
-Scott
Dont forget to Check out Progress on my RaceCar
Project Blasphemy [email protected]
Low 8 Second Street Car...
S2H is offline   Reply With Quote
Old 05-06-2014, 01:14 AM   #15
MattKatz
Launchin
MattKatz's Avatar
so you are saying they don't want the Holley Wired to a junction Block distributor which is the first stop for power. This is how I was planning on doing mine, but is there really a problem with doing it this way?
"Current TBSS Record Holder & Worlds Only 8 Second TBSS"
MattKatz is offline   Reply With Quote
