Bargain build 16 inj vic jr efi conversion - Yellow Bullet Forums
Old 12-15-2013, 06:14 PM   #1
Small block guy
Launchin
Small block guy's Avatar
Default Bargain build 16 inj vic jr efi conversion
Thought this was a good point to build an injector bung jig
drilled through a bolt to make a drill bit guide
bolted a plate to the end piece, flipped them trying to even out some flow
[URL=http://s1092.photobucket.com/user/Smallblockguy/media/dec2013087_zpscaa0d48d.jpg.html][IMG]http://i1092.photobucket.com/albums/i411/Smallblockguy
https://www.yellowbullet.com/forum/sh...d.php?t=623953 dual injector ls efi victor jr bargain build intake thread
Turn key Dual fuel turbo iroc for $14500!!
http://www.racingjunk.com/Complete-R...eek-build.html
Small block guy is offline   Reply With Quote
Old 12-15-2013, 06:18 PM   #2
Small block guy
Launchin
Default Re: Bargain build 16 inj vic jr efi conversion
3085_zps0bfbcf4f.jpg[/IMG]
first blend
injector bungs get bolted to the jig while they are welded in
Old 12-15-2013, 06:24 PM   #3
Small block guy
Launchin
gonna have to cut some of the angle iron down. Don't think this is low enough in the runner?
Old 12-15-2013, 06:58 PM   #4
88mmRocket
88mmRocket's Avatar
Looks like a ton of work! Can't wait to see it done!
Why the Jr.? What are your plans/reason with not starting with another maniford? Also, thoughts on increasing the plenum area?
Looks good so far!
stock block junk
B&K Performance
Ultimate Convertor Concepts
LJMS
A veteran is someone, who at one point in his or her life, wrote a blank check made payable to the United States of America for an amount of "Up to and including my life."
Thank you for those who have served and continue to serve.
88mmRocket is offline   Reply With Quote
Old 12-15-2013, 07:50 PM   #5
Small block guy
Launchin
Looks good so far!
It is a shit ton of work, loving it though.
It's just what I had. It was a good deal.
I am trying to even the flow with the four corner runners vs the middle more so than increasing total plenum area. I also am looking to create a smoother radius in the elbow
Old 12-15-2013, 08:49 PM   #6
Steedafied
Member
Pullin gears
Steedafied's Avatar
Sweet looks good nice work. You've got balls that's definitely a lot of work.
Steedafied is online now   Reply With Quote
Old 12-15-2013, 09:24 PM   #7
rdub79
Platinum Member
rdub79's Avatar
Looks killer, I love shit like this! Keep the pics coming!!
88' Junk-N-Da-Trunk
rdub79 is offline   Reply With Quote
Old 12-15-2013, 10:15 PM   #8
Small block guy
Launchin
Looks good so far!
My plan is 8 gasoline injectors and 8 methanol injectors in an octane on demand setup
Old 12-15-2013, 10:54 PM   #9
2stroke
Member
Pullin gears
2stroke's Avatar
great work, keep the pix coming! I love home brewed stuff like this!
2stroke is offline   Reply With Quote
Old 12-16-2013, 06:19 AM   #10
slow8.0
slow8.0's Avatar
Very Cool Man!
slow8.0 is offline   Reply With Quote
Old 12-16-2013, 08:35 AM   #11
brianj5600
I started to do this but noticed the end runners had smaller cross section. It looks like you significantly shortened the end runners. Does shortening the end runners reduce flow?
67 Mustang Coupe, 351w turbo blow thru,
c4, 8.8
brianj5600 is offline   Reply With Quote
Old 12-16-2013, 08:47 AM   #12
Small block guy
Launchin
Does shortening the end runners reduce flow? No. Reduce velocity? Yes.
Old 12-16-2013, 08:56 AM   #13
Small block guy
Launchin
Here's an example https://www.yellowbullet.com/forum/sh...d.php?t=562528
Old 12-16-2013, 09:05 AM   #14
Small block guy
Launchin
Those intake runners were not modified near as much, but increasing the elbow/plenum area smoothed out flow substantially.
Old 12-16-2013, 09:34 AM   #15
deadhorse66
deadhorse66's Avatar
Nice looking work. What is the purpose of the spike on the front and rear of the plenum besides adding volume?
deadhorse66: head wrench for tim99ws6, small turbo/275 radial
Special Thanks to our sponsors:
MidWest Chassis
AEIcnc
Cage Rage Chassis
Race Wire Solutions
Ace Racing Transmissions
deadhorse66 is offline   Reply With Quote
