New M/T 275 Radial on my leaf car - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 06-30-2012, 04:37 PM   #1
67AfroMaro
That guy...
67AfroMaro's Avatar
Default New M/T 275 Radial on my leaf car
We normall run a M/T 26x8.5 tire but last night we decided to give the new M/T radial a try and it didn't go very well.
Three hits, three failures... anyone wanna take a stab?
I feel like we were completely lost and really want to have a game plan before we go back out.
PASS 1
VIDEO - http://www.youtube.com/watch?v=nV6UZVI2wN0&hd=1
Tire = 18 PSI
Launch = 3400 RPM
Front Travel = 4"
Front Shock Ext = 3/4 Stiff
Front Shock Comp = Full Stiff
Rear Shock Ext = 50% Stiff
Rear Shock Comp = 3/4 Stiff
PASS 2
VIDEO - http://www.youtube.com/watch?v=46857tlhftc&hd=1
Tire = 18 PSI
Launch = 3500 RPM
Front Travel = 4"
PASS 3
VIDEO - http://www.youtube.com/watch?v=pxfyiyEu_LY&hd=1
Tire = 18 PSI
Launch = 3500 RPM
Front Travel = 4"
Front Shock Ext = 1/4 Stiff
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 06-30-2012, 04:56 PM   #2
DOTracer
DOTracer's Avatar
Default Re: New M/T 275 Radial on my leaf car
I'd say the last run the front rebound was too soft. Popped up too quick, dropped down and unloaded.
The order looked like it spun fairly far out and each next video is spun sooner.
How was the track prep and track temp?
Just looking at your shock settings, I would have tried the rear shock rebound softer and set the compression at max firm.
What kind of rear suspension? What power adder if any?
DOTracer is offline   Reply With Quote
Old 06-30-2012, 05:05 PM   #3
DOTracer
DOTracer's Avatar
The first run looked to to be your best of the three. Usually with my N/A car on 275's, if I can make it 5 or 10 feet it'll stay hooked up the whole run. I can't help but wonder if there was something to the track prep where the VHT wasn't sprayed very far out, something with the start line pad transition, or something to make the tire let go where it did.
You made it pretty much to over 2 seconds till the tire spin set in which really the car should have been go to go for a full run. I could see if you were aggressively adding power around that time, but all I see on your graphs is timing ramping back in from maybe a launch retard?
Old 06-30-2012, 05:27 PM   #4
67AfroMaro
That guy...
67AfroMaro's Avatar
Thanks,
I also thought the first pass looked the best but it bogs hard off the hit and knocks the tire off as soon as we give it power from the timing ramp... The track is not known for being great but it didn't seem like junk either.
The last pass was a ton looser on the front with less timing out on a longer ramp to try to plant the rear... didn't work at all but on the previous passes the front looked way too stiff... like a chassis car... also looks like no travel although we measured 4".
1st pass also had the lower launch RPM
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 06-30-2012, 06:31 PM   #5
Widow_Maker
Chupa Cabra
Widow_Maker's Avatar
Take the compression to full stiff in the rear and a looser extension in the rear, try the front where it was on the first pass. See where that gets you.
RTCTTFMF!!!
[email protected] (1.21 60') True Street 275 (3290# RW) SOLD
Smallwood Race Developement
Mcleansville, NC
864-723-2892
Widow_Maker is offline   Reply With Quote
Old 06-30-2012, 06:45 PM   #6
Toaster64
Toaster64's Avatar
DJ, your g-meter seems way low, you need an initial hit of at least 1.90 ish. Those tires like to be hit hard and then ramp the power in quickly and evenly. On the first pass you never hit them hard and so they were never really planted and that's why they broke loose when you applied power.
First, you need to loosen the extension on the rr shocks to 1/4 stiff as a baseline (you may need to go looser). Leave the front ext 1/4 stiff too. Then leave with more power, Whether it be timing or rpm, however you do it with those backwards turbochargers .
Another thing is I tried my tires at 18 and but needed more bite so I ended up at 17.5 which seemed to help...
Where are you testing at? Must be nice
Follow me on Instagram: @Toasterjones
Sponsors:
Deeds Perfomance
QMP Racing Engines
Fab-Tech
Mickey Thompson
Mike's Transmissions
Precision Turbo
ARP
Ross Pistons
DJ Safety
Wilwood Brakes
WEST COAST GRUDGE RACER
Toaster64 is offline   Reply With Quote
Old 06-30-2012, 06:47 PM   #7
Toaster64
Toaster64's Avatar
Quote:
And yes, max out your rr compression.
Sponsors:
Deeds Perfomance
QMP Racing Engines
Fab-Tech
Mickey Thompson
Precision Turbo
ARP
Ross Pistons
DJ Safety
Wilwood Brakes
Old 06-30-2012, 06:54 PM   #8
n8secstangg
n8secstangg's Avatar
seems like a lot of front end travel
ULTIMATE STREET PROJECT..... GAME ON!!!!....OOPS....game off I guess
363" TFS High Ports,EFI, M1 and an S480
[email protected] and [email protected] on drag radials
NOW A DEALER FOR
Kaenen Composites
Champion Wheels
Big Stuff 3
Lightning Force Performance
NLR Systems
Racecraft Inc
Speedwire Systems
n8secstangg is offline   Reply With Quote
Old 06-30-2012, 07:45 PM   #9
67AfroMaro
That guy...
67AfroMaro's Avatar
Quote:
You stagger the right rear? Independent from the left rear?
Congrats on the fast passes...
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 07-01-2012, 12:18 AM   #10
67AfroMaro
That guy...
67AfroMaro's Avatar
The 8.5's have held up to 1.8 G and that makes for a much nicer run. Next time out I'll try to hit the tire with more timing and see if it likes it... it's just so crazy to spin and add power to correct it.
I have a light car so I'll try less on the tires as well (I was told to start at 18 and og up from there).
We were testing at Sac... we were gonig to go again today but after last night, I didn't want to go and waste a day without having any real direction.
I also think the converter is wrong. On the shift we see a 1600+ RPM drop and it tries to (actually does) knock the tires off...
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 07-01-2012, 12:44 AM   #11
Elowe65
Spooled up
Elowe65's Avatar
Pretty sure he means max both rears (rr) out, not staggered.
Elowe65 is offline   Reply With Quote
Old 07-01-2012, 12:09 PM   #12
Widow_Maker
Chupa Cabra
What does your car weigh DJ?
Mine weighs 3002lbs race weight and for example on the 275/60 Hoosier I run 18-19psi of air. I know I could possibly go lower being my car is probably even lighten than yours, but I like to not have any sidewall distortion or flex on my car which I get at 16psi. Not so much at 17psi, but at 18-19psi it leaves a nice contact patch for my liking and seems to get up on the tire faster into the run.
I'd also try between 18-19psi on your car if it weighs what I think it does(3200?)
RTCTTFMF!!!
Mcleansville, NC
864-723-2892
Old 07-01-2012, 12:17 PM   #13
67AfroMaro
That guy...
67AfroMaro's Avatar
A little over 3100, we were at 18 PSI and thought about 17.5 but I didn't want the extra variable.
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 07-01-2012, 03:42 PM   #14
KellyBlackGT
H&H Racing
KellyBlackGT's Avatar
1.9? Thats it?
H&H Racing 2015 TT5 Sponsors:
Unlimited Products
ProCharger Superchargers
Addiction Motorsports
Chris Alston's Chassis Works
Component Drive Systems
Holley EFI
https://www.facebook.com/pages/HH-Ra...871169?ref=hl#
1.12 [email protected] on 275s
1.16 [email protected] [email protected] 3460lbs &275s
KellyBlackGT is offline   Reply With Quote
Old 07-01-2012, 03:46 PM   #15
8TREEZ
Member
Pullin gears
8TREEZ's Avatar
fronts too loose, and you need to get it to hit the tire harder. if you loosen the extension on the rear and tighten the compression i think you will see a huge difference.
Keith
www.unleashedracing.net
www.lgmrnd.com
https://m.facebook.com/skinnypeteperformance
Skinny Pete Performance
Home of the Bolt in Mustang Throttle Pedal.
PM me for details.
8TREEZ is offline   Reply With Quote
