Dyno results for my JY 6.0L - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 02-12-2012, 12:48 PM   #1
3pedals
Gigity
3pedals's Avatar
Default Dyno results for my JY 6.0L
not too shabby for a JUNKYARD DOG
30Kmile LY6
850 Mighty Demon on a 1" open spacer, on a L92 VIC Jr( injector bosses removed from runners)
Edelbrock 1 3/4"-1 7/8" headers
head cut for 11.0:1 compression no real porting, just cleaned up
OEM pistons flycut .070"
Bret Bauer spec'd cam(236/262,110, .6xx, .625") and valvesprings, pushrods.
30K mile oem lifters
ARP head studs and rod bolts
moroso electric waterpump, no other acc.
98 Fbody pan, tray
93 octane pump gas
31* timing, verified with a pinned ATI damper and timing light
12.8 A/F
I think I need to put in a ROLLCAGE soon, not just a bar like I thought.......
hard to read, but its the best I can do:
3pedals is offline   Reply With Quote
Old 02-12-2012, 01:46 PM   #2
LilJohn
LilJohn's Avatar
Default Re: Dyno results for my JY 6.0L
26 degree exhaust split?
Whats the intake centerline?
Not bashing.... Trying.to learn something........ That is unbelievably stout man. Peak torque at 5300 and the horsepower is still climbing at 7500 with a 236 degree intake lobe.
888-583-4408
www.LilJohnsMotorsports.com
[email protected]
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 02-12-2012, 01:50 PM   #3
Dudek
Pre-Staged
very nice, im hoping to do something very similar before summer hits.
Dudek is offline   Reply With Quote
Old 02-12-2012, 02:03 PM   #4
93hatch
93hatch's Avatar
jesus thats going to crush the old times in your sig. Stock rockers? ls7 lifters?
93hatch is offline   Reply With Quote
Old 02-12-2012, 02:08 PM   #5
3pedals
Gigity
3pedals's Avatar
installed strait up. stock rockers, stock '07 re-used lifters
as for the cam specs, thats all Bret, he figured out the valvetrain from the lobes to the valves to get it to work like this.
After the first couple pulls the dyno was showing 666hp @ 7500, and Dale the dyno owner decided we needed to re-calibrate it, because the numbers were rediculous. the next pull it came down to 618, and from there we fine tuned it with various spacers/timing/jetting to get to where it is on the run above.
Thanks for the compliments, hope it runs as hard on the track as the dyno.
Old 02-12-2012, 02:08 PM   #6
93hatch
93hatch's Avatar
just read oem lifters, dam
Old 02-12-2012, 02:15 PM   #7
LilJohn
LilJohn's Avatar
Ok... now i see that lobe going that high.... now i understand the extra exhaust duration....
Bro... i know Built bottom end motors that people have spent BIG money on that do not make that kinda power.
Id be very happy...... Hell Im Very impressed.
i wanna map that camshaft. lol
888-583-4408
[email protected]
Old 02-12-2012, 02:20 PM   #8
3pedals
Gigity
3pedals's Avatar
I am!!
you have to talk to Bret about the cam
Old 02-12-2012, 02:22 PM   #9
Pro Stock John
Pro Stock John's Avatar
Nice power, so the power is fairly flat... so where you thinking of shifting it? I'd love to heard how it does, take a lot of notes!!
LSX RECORD LIST
Pro Stock John is offline   Reply With Quote
Old 02-12-2012, 02:29 PM   #10
deadhorse66
deadhorse66's Avatar
WOW, that's a monster. I'm not familiar with that brand of dyno, how does it compare to a dynojet, dynocom, dyno dynamics, etc in terms of being loose? Even on a really loose dyno, that's big.
Did Bret do the heads too? I knew they liked a lot of split, but I didn't think it was quite that much. Then again, I can't even begin to understand heads on the level that guys like him do. I wonder if it has anything to do with it being carbureted? Hoping he'll chime in and give some insight for those of us trying to learn something. Can't wait to hear what it does at the track!
deadhorse66 is offline   Reply With Quote
Old 02-12-2012, 02:33 PM   #11
3pedals
Gigity
3pedals's Avatar
Quote:
well originally we thought it would peak at 72-7300ish, and the power would hang on to 7700 ish where I'd shift. unreal that it held enough torque to build more hp up to 75-7600.
I dont want to push my luck TOO FAR with the original pistons, so I'll keep 7700 as my shift point and set the limiter to 7800
Old 02-12-2012, 02:37 PM   #12
3pedals
Gigity
3pedals's Avatar
I really dont know anything about this dyno either, but Dale dyno's a fair amount of engines, and he is impressed with this thing's output too.
As for porting, there is none, I just cleaned up some rough casting in the ports myself, and the valvejob is oem, I just lapped the valves to make sure they would seal, there is 30K miles on the heads.
Old 02-12-2012, 03:30 PM   #13
deadhorse66
So it's a flywheel dyno?
Old 02-12-2012, 03:41 PM   #14
3pedals
Gigity
3pedals's Avatar
yes
Old 02-12-2012, 04:32 PM   #15
93hatch
93hatch's Avatar
got a link to the balancer youre running?
