275rs class added to ultimate outlaw shootout series - Yellow Bullet Forums
Old 05-15-2011, 01:48 PM   #1
broncomania
Mike Case
broncomania's Avatar
Default 275rs class added to ultimate outlaw shootout series
thanks adam & nate. and thanks john sears for lining it all up.
at piedmont dragway may 28th. (ONLY)
rules:
275RS
*BODY & GLASS:
Must have working headlights, tail lights, Stock appearing interior, carpet, door panels, factory
"type" dash, stock floor pans, stock firewall.
single seat ok.
Lexan permitted must be neat in appearance.
forward facing hood scoops and rear wings ok.
fiberglass limited to hood and decklid or hatch only.
*SUSPENSION:
No wheelie bars or 4 link suspension.
must have stock type suspension with factory frame rail or ladder bar with factory frame rail.
Coil overs and anti roll ok.
*TIRES:
-Maximum rear tire size allowed is 275/60-15 designation.
these radial sizes are equivalent to a 275 >
Size /wheel Size/ Equivalent
P275/60R15 /15"/ 28 X 11.50R15
P295/50R16 /16"/ 28X11.50R16
P295/45R17 /17"/ 28X11.50R17
NO HOOSIER DRAG RADIALS
Tire must be used as intended from manufacturer. No alterations
permitted.
*POWER ADDERS:
Single type power adder only.
nos:
no multi stages.
no splitting of foggers or controlling nos flow electronically in any way. must use wot or toggle switch.
1 nos bottle in car.
no foggers on bb
double cross bar plates allowed.
nos sb max .082 jet on plate and max .026 on fogger
nos bb max .068 jet on plate
Nitrous entries maximum jetting
Small block, 6cyl and 4cyl
1 jet - .082
2 jets - .057
4 jets - .035
6 jets - .030
8 jets - .026
*FORCED INDUCTION:
no billett wheels allowed
max turbo size 76mm measured tip to tip. (no reducers allowed to achieve this size !!!!) no clipped wheels !!!!!!
max s/c sizes D1,V7,JT,NOVI 2000,KB 3.6
no boosted bb engines
air to air intercooler OR water meth injection with gas only. ( may not use both together)
air to water allowed with weight penalty . (see weights for description)
*EXHAUST:
must have mufflers on all entries except turbo cars.
*CYLINDER HEAD / ENGINE INDUCTION:
maximum cid limit : sb 427 / bb 525 with stock deck height.
4150 carbs only
23*chevy, 20*ford, 18*mopar, 15*ls, on sb only
mod motors ok, twisted wedge heads ok , (twisted wedge R heads ok with weight penalty, see weight for description)
bb heads are conventional style only with factory valve angles.
buick, pontiac,olds combos can run at sb weight (nos or n/a only)
no sheetmetal intakes.
no dry sump oil systems.
no clutchless type transmissions.
*FUEL:
pump gas , race gas , e85 ok
*ELECTRONICS:
ignition boxes limited to standard type 6 series only.
no slew, no traction control, no boost controller, no nos controller .
msd 6530 permitted on all combos.
add on boost reference timing retard boxes allowed.
digiset allowed on plate only.
piggy back ok .
stand alone efi fast or bs3 ok with weight penalty. (see weight for description)
*WEIGHT:
4cyl - turbo, nos, or s/c 2800
v6 - nos 2950
sb n/a - 2750
sb nos - 3150 (see nos for allowed combos)
sb & 6cyl boosted 3250 ( see forced induction for allowed combos)
bb n/a 3000
bb nos 3300 (no foggers)
deduct 50lbs for 70mm and smaller turbo or s/c listed in forced induction.
deduct 50lbs non intercooled
deduct 50lbs on sb with cast iron heads.
add 100lbs for a/w intercooler
add 50lbs for twisted wedge R heads
add 50lbs for stand alone efi (fast & bs3)
entry fee:
$40.00
payout: (paid by mac-fab performance beadlocks, ndrra, piedmont dragway)
$500.00 to win and 1pair of GOODYEAR 275's if running decal and win on goodyear tires.
$200.00 runner-up
$50.00 semis
#1 qualifier $50.00 (paid by fastlane motorsports)
looking for more sponsors for this class at this event .
East Coast Surplus & Tactical
336-674-3868
broncomania is offline   Reply With Quote
Old 05-15-2011, 02:07 PM   #2
Dentfix
Default Re: 275rs class added to ultimate outlaw shootout series
Hell yea , gonna be a huge show!! Hope reed can get me my turbo back in time to get on a dyno before then.
Dentfix is offline   Reply With Quote
Old 05-15-2011, 02:23 PM   #3
BACARTY
The Bullet Killer
BACARTY's Avatar
how do these rules compare to john sears rules?
i ask cause Nate's Ultimate outlaw race runs johns rules and will be at piedmont. Hoping some guys can do both races
BACARTY is offline   Reply With Quote
Old 05-15-2011, 02:42 PM   #4
moneypit
moneypit's Avatar
Most of the RS cars run 50s at best so far. NOS,Turbo, and ci restrictions plus no hoosiers.
4.86- Eddy SC1 SBF 1 Fogger X275
4.89- BT3.6 SBF 2 foggers X275
4.96- Pro Action SBC/4150 1 Fogger Nitrous X
He told me it would run 4.80s. And then he proved it ! Handy Racing Engines
keep an eye on us here >>http://handyracingengines.blogspot.com/
moneypit is offline   Reply With Quote
Old 05-15-2011, 04:16 PM   #5
Drag Radial
SOFA KING WHAT?
Drag Radial's Avatar
B, the guys that run 275RS run 5.50 - 6.0 for the most part, they run with Mike's series inconjuction with X275. Plenty of cars to go around for each class in that area.
Quote:
Originally Posted by Monte Smith View Post
You CAN'T make rules based on what guys HAVE..........you have to make rules based on the POTENTIAL on any given combo. FAIR is next to impossible..............plus FAIR is a place where they have rides and pigs are judged, has nothing to do with racing..............LOL!!!
Monte Smith
Drag Radial is offline   Reply With Quote
Old 05-15-2011, 04:28 PM   #6
NOS42
NOS42's Avatar
looks like a fun and affordable class......good luck!
NOS42 is offline   Reply With Quote
Old 05-15-2011, 05:06 PM   #7
senior
senior's Avatar
Gonna make a great day of heads up racing even better! Glad to have you guys
Adam
senior is offline   Reply With Quote
Old 05-15-2011, 06:38 PM   #8
harleyman9696
harleyman9696's Avatar
It would be cool to try and run these at all the ultimate outlaw races ...including milan...but why the 525 bbc limit ...540/555/565 is so common at the tracks seems your excluding tons of cars ...hell very few people build under a 540 unless is to class like NMCA ...just asking the question...or is there a weight penality for being over ??? I could run both as my combo is a 555 with a plate...
harleyman9696 is offline   Reply With Quote
Old 05-15-2011, 06:55 PM   #9
turbotbirds
turbotbirds's Avatar
Cool deal!!! Thanks Nate and Adam for allowing us to race at your race, we will not disappoint!
275 True Street (CHRA), Street Race (KOTS), Ultra/Ultimate SBC Methanol Blowthru
Forced Inductions Billet 76mm
LJMS Custom camshafts
[email protected] 140
turbotbirds is offline   Reply With Quote
Old 05-15-2011, 07:01 PM   #10
jsalvato1
jsalvato1's Avatar
Can't wait for Piedmont!
Salvato Designs
www.salvatodesigns.com
[email protected]
Join our Facebook page
Offering products such as Logo Design, Business Cards, Hero Cards, Flyers, Posters, T-Shirts, Crew Shirts, Embroidery, Vinyl Decals, Window Lettering, Full Color Printed Banners, Pit Signs & More!
Authorized X275 distributor
jsalvato1 is offline   Reply With Quote
Old 05-15-2011, 08:11 PM   #11
Fastmover
Smoke Em if you got Em
Fastmover's Avatar
I loved this class at Civil wars, Bring on the FearMONT!
WWW.FastMoverMotorsports.com
Thanks to
Precision Turbo and Engine
BIG STUFF 3
Mickey Thompson Tires
JPC Racing
RGR Engines
Baer Brakes
Double AA Performance
TRZ Motorsports
RaceCraft, INC.
CP-Carrillo Pistons
RacePak
PAC Springs
DJ Safety
Davis Technologies
Salvatto Designs
www.feathercarbon.com
Quote:
Originally Posted by SRTthis View Post
so you want a weight break for not knowing what the fuck your doing?
Quote:
Originally Posted by Steve Jackson View Post
Im going to bring redneck to the middle east.
Fastmover is offline   Reply With Quote
Old 05-15-2011, 08:39 PM   #12
broncomania
Mike Case
Quote:
thanks again adam. we really appreciate it. i'll be there early to tech .
336-674-3868
Old 05-15-2011, 08:46 PM   #13
LilJohn
LilJohn's Avatar
Is there any kind of cubic inch limits on 4 cylinder entries?
Are the trickflow LS heads not legal since they are not 15 degree?
888-583-4408
www.LilJohnsMotorsports.com
[email protected]
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 05-15-2011, 09:16 PM   #14
n8tr
n8tr's Avatar
Location: Punching like a girl with a drink in my other hand somewhere.
He'll yeah guys! Can't wait to check out this additional 275 class. How many of you are going to try to run both classes?
NATE AND ADAM ARE REALLY GOOD AT PROMOTING RACES, PARTYING, AND BEING GREAT FRIENDS. THEY JUST SUCK AT RACING. - TOMMY KUNDRIK 2014
n8tr is offline   Reply With Quote
Old 05-15-2011, 09:22 PM   #15
broncomania
Mike Case
all ls heads must be 15* . no ci limit on 4cyl entry.
harleyman , the bb ci limit is not just chevy , its all bb IE: FORD ,CHEVY, MOPAR. that ci limit will stand at this time. i'd like to keep the rules the same for the remainder of the year. unless something drastic happens. thanks.
336-674-3868
