Fuck it... Turbocharging 102: Turbo system design - Yellow Bullet Forums
Old 12-03-2010, 06:39 PM   #1
95mmRenegade
Default Fuck it... Turbocharging 102: Turbo system design
This thread will be dedicated to turbo system setup and design. Lets discuss
1) Header design, Size and construction
2) Crossover tube design, size and construction
3) How do you choose the correct turbocharger
4) Exhaust sustem basics
5) Wastegate installation and optimal performance
Who wants to start?
Phil - ProStreet Motorsports
"The Renegade" - Best 1/8 4.62 @ 153 -
2000 Mustang #227N
Virginia Speed 450" LSx
John Marcella Sheetmetal Intake
NLR AMS-1000 Power Management
95mmRenegade is offline   Reply With Quote
Old 12-03-2010, 06:41 PM   #2
madman
Launchin
Default Re: Fuck it... Turbocharging 102: Turbo system design
You must be feeling better.
www.madmanandcoracing.com
madman is offline   Reply With Quote
Old 12-03-2010, 06:41 PM   #3
sg67nova
sg67nova's Avatar
Subscribing....thinking about coverting from nitrous to turbo down the road. Thanks.
sg67nova is offline   Reply With Quote
Old 12-03-2010, 06:42 PM   #4
95mmRenegade
Quote:
I'm getting there slowly but surely. That medicine almost took the life outta me.
2000 Mustang #227N
Old 12-03-2010, 06:43 PM   #5
motard1
Member
Pullin gears
I would start,but I know shit about turbos. Have been thinking about a turbo BBC in a foxbody.
motard1 is offline   Reply With Quote
Old 12-03-2010, 06:44 PM   #6
95mmRenegade
Quote:
Have you read maximinum boost?
Old 12-03-2010, 06:45 PM   #7
motard1
Member
Pullin gears
Quote:
Nope. Is it a book? If so,where do I get it?
Old 12-03-2010, 06:56 PM   #8
95mmRenegade
- Header design is a very important piece in the turbocharger system. Many people ask if the header tubes need to be equal or unequal length. The best headers would be designed to be equal length with the smallest tube size that will work with the given engine combo. There is really no gain by going to a larger header tube like a NA motor, actually it has been documented to that a larger header tube will slow the velocity of the exhaust gas and reduce the speed that the turbo spools. Thick qualify flanges should be used, 4 bolt or v-band clamps should be used between the header and crossover tube to ensure a leakfree connection. Coating or header wrap will help retain the heat in the header tubes and should be used. As far as sizing... We've used 1 3/4" on a 438" and had very good results. I'd almost recommend going to a smaller tube on a 370-380", maybe a 1 5/8" or 1 1/2". The key is making sure the exhaust tube does not shroud or block the port exit at the cylinder head. The overall sizing of the header tube will play more into turbo spooling than anything else. The idea is to keep the exhaust gas velocity high but there is a point where it exceeds the speed of sound and the exhaust gases start doing some funny things.
Please feel free to correct, add or tell me to shut the fuck up.
Old 12-03-2010, 06:58 PM   #9
95mmRenegade
http://www.amazon.com/Maximum-Boost-.../dp/0837601606+
Old 12-03-2010, 06:59 PM   #10
chrisevans
Godspeed TK!
chrisevans's Avatar
OK!!!!LOL
You asked for that one Phil!!!!
[email protected] F1A-94 2016 Ultra street "Northeast"
Thanks to-
~ROCHE Racing engines(410)285-7250
~PROCHARGER
~MB racing
-County speed @ fuel
~Fourcade transmissions
~Mac-fab beadlocks
~Team Z motorsports
~Schoneck composites
~VP racing fuels
~PPC converters
chrisevans is offline   Reply With Quote
Old 12-03-2010, 07:14 PM   #11
95mmRenegade
Thank buddy! LOL
Old 12-03-2010, 07:16 PM   #12
Shearer
Shearer's Avatar
This should make for a great read! lol
Borg Warner, Callies, DART, Davies Craig, Diamond Pistons, Earls, Forced Performance, Garrett, Holley, K1, Precision Turbo, Stainless Works, TiAL, Trick Flow, Turbosmart, Vibrant, Wiseco, Xona Rotor Turbos
Dealer inquiries are welcome
216-242-2909
www.shearerfabrications.com
[email protected]
Shearer is offline   Reply With Quote
Old 12-03-2010, 07:18 PM   #13
Suicidal Racing
ls1 s/s notch on 28s
Suicidal Racing's Avatar
Who wants to start?
383ci sbc chevy
1) 1" 5/8th headers non equal length
2)2.5" for cross over Y pipe design..i've thought about maybe when it gos from 2 to 1 pipe to use 3" for that section..not sure if it would be good or not
3) 88 large frame with t6 with 1.32 a/r if bw..not sure a/r for a pt or garret..but i know from just reading a ton of info that is the optimal size turbo for that size motor.
4) exh would be down pipe really with it being 45 degrees coming off the ass end of the turbo seeing it would be a front mount and then angled cut down..pipe length would probley be 2' long probley
5)waste gate would be placed at the leading curve of the 90 going into the turbo..that way its a straight shot out
everything would be v band clamped at all the joints..
Now pick it apart turbo gurus
Tony laino
Suicidal Racing is offline   Reply With Quote
Old 12-03-2010, 07:20 PM   #14
Bartman2
Member
Pullin gears
Gases don't really flow faster than the speed of sound. At the speed of sound gases are get kinda stall from the turbulence of the sound barrier.
One big think to remember is the speed of sound increases substantially when pressure is increased. So basically when the exhaust approaches the speed of sound it has to increase in pressure to flow faster.
Our lady of blessed acceleration don't fail me now
Bartman2 is offline   Reply With Quote
Old 12-03-2010, 07:32 PM   #15
tomato
by this reasoning a large tube header will spool the same as a small tube. pressurely thinking of course...
tomato is offline   Reply With Quote
