divided-vs-undivided turbos - Yellow Bullet Forums
Old 10-14-2010, 02:16 PM   #1
quick-silver
quick-silver's Avatar
Default divided-vs-undivided turbos
Im looking into running 2 s366 turbos on a 23* brodix headed sbc 383cu on e-85.
My question is: is there a large power/spool difference if i run divided or undivide turbine housings. There are 2 different options .91 ar divided or .91 undivided. Everything else is exactly the same.
Which would be a better choice?
quick-silver is offline   Reply With Quote
Old 10-14-2010, 02:56 PM   #2
DrTurbo
DrTurbo's Avatar
Default Re: divided-vs-undivided turbos
The .91A/R divided will spool a little quicker then the un-divided. A/R's are calc. as a total area of scroll. So the divided is actually a smudge smaller then a .91 undivided as far as area is concerned.
Forced Inductions.com
1-(256)-796-1230
1-(256)-658-5798
Authorized Distributor/Dealer and Builder of:
Garrett
Borg Warner
Holset
Turbonetics
Precision Turbo
Mitsubishi
Rajay
IHI
DrTurbo is offline   Reply With Quote
Old 10-14-2010, 03:10 PM   #3
quick-silver
i assumed the divided would spool quicker but didnt know how much faster or if the divider would become a potential restriction.
Im looking to make about 900whp and run some 8.80-8.90 in a 3300lb car.
Sounds like either would work then?
Old 10-14-2010, 05:15 PM   #4
ScorpionT
Spooled up
Either one will do the job just fine, just depends how you want to build the manifolds. I generally prefer divided housings for better efficiency, but for drag its not a huge issue.
ScorpionT is offline   Reply With Quote
Old 10-14-2010, 08:18 PM   #5
rick head
Member
Pullin gears
rick head's Avatar
You would be hard pressed to find any benefit from a divided housing with a 90 degree crank application using conventional turbo headers on E-85 or gas.
Personally I would run the undivided as the divider often creates a perfect riser for stress cracks often associated with EGT of E-85 and gas applications.
You can't be a hazz been if you never wuz
www.exileturbo.com
rick head is offline   Reply With Quote
Old 10-17-2010, 07:50 AM   #6
turbo chicken
Member
Pullin gears
turbo chicken's Avatar
I vote for undivided. I build lots of turbo manifolds and undivided wins hands down for ease of plumbing. To do it properly with a divided housing you should run 2 wastegates to avoid mixing up the gasses from both sides of the manifold which defeats the purpose of having a divided housing in the first place. An undivided housing is also a fair bit lighter.
turbo chicken is offline   Reply With Quote
Old 10-17-2010, 11:27 AM   #7
Shearer
Shearer's Avatar
We've done a lot of testing and there is no advantage to it. Keep backpressure between the two configurations the same and there is no difference between the two.
Borg Warner, Callies, DART, Davies Craig, Diamond Pistons, Earls, Forced Performance, Garrett, Holley, K1, Precision Turbo, Stainless Works, TiAL, Trick Flow, Turbosmart, Vibrant, Wiseco, Xona Rotor Turbos
Dealer inquiries are welcome
216-242-2909
www.shearerfabrications.com
[email protected]
Shearer is offline   Reply With Quote
