79 "Credit Limit" Malibu - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > GM Builds
GM Builds Share all GM builds in this section.
Old 11-27-2018, 06:58 PM   #1
Flatblack79v2
Member
Pullin gears
Flatblack79v2's Avatar
Garage
Default 79 "Credit Limit" Malibu
Figured it was time to start my own thread. Bear with me on this first post ill try to keep them short after the story of the car is laid out.
I bought this 1979 Malibu back in 2010 before I even had a drivers license. Had a 305 with a spun rod bearing.
Heres a few pics i still had on Facebook of the day i got the car.
My dad had a splayed cap 383 engine with some cast iron bowtie heads so we put it in the car. Dynoed at 390 HP to the wheels. This was some time around 2011.
Graduated HS in 2012 and got a job as Summit Racing. so with the hook up on parts i got a Moser M9 housing for the car, redid the exhaust with some 1-7/8" to 3" Headers, magnaflow mufflers, G-force trans crossmember. This was some time around 2013 when this happened.
Took the car to the track twice and it never made a pass. Rained out first trip, second trip MSD box took a shit as soon as it came off the trailer. I got discouraged and the car has sat for the last 4 years while ive been in college. Swore up and down id never touch it again... thats turned out to be false.
If you can't explain what you're doing as a process, you don't know what you're doing. - W. Edwards Deming
1979 "Credit Limit" Malibu
Instagram @buddies_garage
Youtube: Buddies Garage https://www.youtube.com/channel/UCrk..._as=subscriber
My Thread:https://www.yellowbullet.com/forum/s....php?t=2551747
Flatblack79v2 is offline   Reply With Quote
Old 11-27-2018, 07:12 PM   #2
Flatblack79v2
Member
Pullin gears
Garage
Default Re: 79 "Credit Limit" Malibu
Ive recently moved and the new house as a 24x32 garage so ive started working on the car again. For it to have sat outside for the last 4 years it has held up pretty well. It has some rust starting on the drivers side quarter but thats pretty much it.
Once in the shop we started looking over the car. We fully expected the engine to be seized up and ruined. Oil was crystal clear, no water, no discoloration. Engine had only ran 4 min since last oil change before going to the track the last time. Pulled the plugs and spun engine over. Spun freely and built oil pressure.
We ended up wiring in a new MSD box and put a fresh set of plugs in it. Car cranked before turning over a full revolution. Didnt even have to put a gasket in carb. It was like the car had waited for me.
With the car running we decided to go on and build the M9 I had laying around for the last 5 years. Dad had a 31 spline spool, 4.30 pro gear, Moser Nodular Iron center section and a MW ball bearing pinion support laying around so we slapped it all together. I also got a cheapo disc brake kit to put on the rear.
Out with the old 4.56 gear 7.5
I ordered some UPR adjustable upper and lower control arms. The uppers had to be modified to work. They have some bracing that hits the ear on rear end.
Got the car back on the ground
Old 11-27-2018, 07:20 PM   #3
Flatblack79v2
Member
Pullin gears
Garage
Well I didnt get post edited within 5 min time limit so heres the pics.
Old 11-27-2018, 07:33 PM   #4
Flatblack79v2
Member
Pullin gears
Garage
With the rear in the car we started doing the brakes. The car still had the original vacuum booster and MC so i got a strange manual MC to convert car to manual brakes.
Also picked up a Wilson Manifold Cross Bar plate. Way overkill for the 383 in the car but it was cheap so I couldnt pass on it.
Got a driveshaft made and installed. Went with 1350 joints and 3" DOM. Should handle anything i could afford to throw at it.
Plans down the road are to build a turbo LS. I ran across a good deal on a LC9 5.3 with a bad crankshaft this past weekend so i snagged it. Aluminum block, 243 heads, truck intake.
In my search for a crankshaft i ran accross this 06 5.3. I know its a gen 3 and the LC9 is a gen 4 but for $100 i figured i could steal the crank and sell the rest.
Old 11-28-2018, 11:24 AM   #5
Quick Mike
Launchin
Well good luck! I've got the same car,It is a little farther along than yours but same car never the less. Mike D.
Quick Mike is offline   Reply With Quote
Old 11-29-2018, 11:16 AM   #6
Flatblack79v2
Member
Pullin gears
Garage
TRZ Anti roll bar came in. Itll probably sit on the shelf for a while before it gets installed.
Plans for the weekend are to finish running brake lines, bleed brakes, then work on reinstalling the seats in the car. Previous owner was a short fucker and had the seats mounted so high and close to steering wheel my 6'4" 330# ass couldnt even hardly get in the car.
Old:
https://lh3.googleusercontent.com/b3...N=w727-h969-no
Id also like to shout out the unofficial sponsor of the build - Miller Lite
And this is how most days end up looking. To much beer drinking and not enough working
Until the weekend thats all i got.
Old 12-02-2018, 05:10 PM   #7
Flatblack79v2
Member
Pullin gears
Garage
Spent some time in the shop yesterday, had to redo half the flares on the brake lines that were ran, and got the brakes bled.
Also tore down the $100 gen 3 5.3 i picked up last week. Was told it lost oil pressure before being pulled. All bearings look fine. Original plan was to steal crank out of it but now im probably going to put new main, rod, cam bearings in it, cam, springs, lifters and learn how to tune EFI on that engine.
Old 12-05-2018, 06:47 PM   #8
Shoedoos
its not often I can't see pix on yb.....but this thread is one occasion.....is anybody else not seeing the pics here?
Shoedoos is offline   Reply With Quote
Old 12-05-2018, 06:49 PM   #9
Flatblack79v2
Member
Pullin gears
Garage
Quote:
I see them. Whats it look like on your end?
Old 12-05-2018, 06:50 PM   #10
naynay
naynay's Avatar
i cant see shit.
i dont understand why people use pay sites to host. you can have a private folder in facebook and dump them all there and link them straight here.
63 c10 - bagged - slow
wtb gbody roller
naynay is online now   Reply With Quote
Old 12-05-2018, 06:54 PM   #11
Flatblack79v2
Member
Pullin gears
Garage
I see what the problem is. Im using google photo and can see them as im logged in on my google chrome. when i sign out photos go away.
Heres a link to all photos until i get another option set up. No wonder this thread has been so dead.
https://photos.google.com/?pageId=none
EDIT: Nevermind that doesnt work either. Mark this up as a fail
Old 12-05-2018, 07:04 PM   #12
Flatblack79v2
Member
Pullin gears
Garage
Quote:
Originally Posted by naynay View Post
i cant see shit.
Ill try that. Been years since ive tried doing this on here. My Photobucket account is wiped out completely and now you gotta pay, fuck that!
Old 12-05-2018, 07:11 PM   #13
Flatblack79v2
Member
Pullin gears
Garage
Alright i apologize for the technical inefficiencies of this OP but lets see if i can get this to work now. Pics are in somewhat order of how they were originally posted.
https://www.facebook.com/dekota.oech...9822119720706/
https://scontent.fatl1-2.fna.fbcdn.n...40&oe=5C6CDF91
Ok i think that worked. Sorry for being a dipshit
Old 12-05-2018, 07:13 PM   #14
naynay
naynay's Avatar
much better!
looking good so far.
hat are you doing with the motor?
wtb gbody roller
Old 12-05-2018, 07:20 PM   #15
Flatblack79v2
Member
Pullin gears
Garage
much better!
The 383 that's in the car currently is going to stay for now. Its a pretty nice piece and was never intended to actually be in a "race" car. Its a super light bob weight 4340 eagle crank, 6" rod, Mohle Piston bottom end with some heavily ported cast iron bowtie heads. Reed solid roller cam i cant remember specs. Came out of a sprint car. The engine runs good for what it is and is a screamer but is going to be on a short life cycle when we lay the juice to it.
Plans for the iron block Gen 3 5.3 engine is to put bearings, rings, cam, springs in it. Im going to pony up and get a Holley Dominator ECU for the car and learn how to tune with that engine. If [when] i blow it up ill only be out a few hundred bucks and wont really care.
the LC9 will get a good bottom end, leave the 243's alone, cam, possibly intake and a s475.
Now if i could find that extra $3000 i had laying around
