need a wiring diagram - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 06-07-2010, 10:46 AM   #1
nos67ss
Grandpa
nos67ss's Avatar
Default need a wiring diagram
I am sure theres one on here somewhere but I need a wiring diagram to ad a digiset timer to delay my nos off the trans brake.
if anyone could help me out I'd appreciate it.
Like Pyott Racing on Facebook
2010/2011 Ultimate Outlaws 8.50 Champion
RaceWires
Induction-Solutions.com
MickeyThompsontires.com
Salvato Designs
Holeshot Racing Wheels
[/URL]www.diamondracing.net/
nos67ss is offline   Reply With Quote
Old 06-07-2010, 06:41 PM   #2
greeze
Member
Pullin gears
greeze's Avatar
Location: Detroit where the weak are killed and eaten!!
Default Re: need a wiring diagram
greeze is offline   Reply With Quote
Old 06-07-2010, 06:42 PM   #3
greeze
Member
Pullin gears
greeze's Avatar
^ my whole collection
Old 06-07-2010, 07:06 PM   #4
nos67ss
Grandpa
nos67ss's Avatar
Thanks!!
RaceWires
Salvato Designs
Old 12-14-2010, 10:40 AM   #5
gryphon68
gryphon68's Avatar
Should bump this to a sticky, the question is always being asked either here or in the electrical section.
Could also post more variations of the same idea, progressives, 7531 timers, etc.
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 12-14-2010, 04:17 PM   #6
Induction-Solutions
Moderator
Induction-Solutions's Avatar
I agree !! Done deal...
Hope this helps you guys out in the future.. Thanks, SJ
Steve Johnson
www.InductionSolutions.com
http://www.facebook.com/#!/pages/Ind...06171102739096
815-341-8853 Cell
352-593-5900 Parts/Shop
[email protected]
Induction-Solutions is offline   Reply With Quote
Old 12-14-2010, 05:04 PM   #7
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
Man, so complicated. All that stuff is done inside my Holley Dominator ECM! Good schematics though for those that need them, keep it here forever.
Mike Beck is offline   Reply With Quote
Old 12-14-2010, 05:59 PM   #8
gryphon68
gryphon68's Avatar
Found a few more . . . .
Quote:
Originally Posted by 388Monte View Post
This is the diagram I wired the car with and it worked out awesome, nice and simple job for sure.
Quote:
Originally Posted by bob g View Post
heres the diagram.... just so your aware, you dont need to wire up the fuel part of the progressive, you can just use the nitrous output and wire the to a continous duty solenoid, than hook both your nitrous and fuel solenoids to it for the first system... this diagram is old and i need to remake it to eliminate that part cause its just a waste of wire and a extra continous duty solenoid...
this is slow94z, i'm on the shop computer under my pop's login...
jay
Quote:
Originally Posted by WardRacing408 View Post
Try this. This diagram puts the WOT switch on the ground side of the circuit as well. Hope this helps.
Beebe Motorsports
Old 01-16-2011, 10:59 AM   #9
90camaro
Pre-Staged
90camaro's Avatar
Question Re: need a wiring diagram
I don’t think I see the one I need here.
The class I am going to run does not allow any type of controller. No digi-sets, no ignition retards, no progressives, nothing.
I want to be able to leave off the brake or a button.
Would I need to use 3 relays? 2 for the Trans brake and one for the button with 2 different activation switches?
90camaro is offline   Reply With Quote
Old 01-23-2011, 09:07 AM   #10
kidroc
Member
Pullin gears
retard that aint going to help you lol i tried that and i still go in the air. if you want to can come look at mine its pretty simple
kidroc is offline   Reply With Quote
Old 02-02-2011, 03:47 PM   #11
nos67ss
Grandpa
nos67ss's Avatar
Quote:
I've had it done for a while now, where you been??
and i'll pass, dont think the masking tape and scotch locs are a good look
RaceWires
Salvato Designs
Old 02-15-2011, 10:18 AM   #12
dcw9360
Spooled up
Why is 85 and or 86 used as ground in these diagrams,,,,, which is really the ground???? schematic with arrow between 85 and 86 on relay means what??? someone please explain
dcw9360 is offline   Reply With Quote
Old 02-15-2011, 11:13 AM   #13
gryphon68
gryphon68's Avatar
Quote:
Sounds like you are referring to a diode across the coil.
If there is no diode then a relay does not care whether 85 or 86 is ground. If a diode is present it does matter. I believe some relays have internal diodes, but I have also used harnesses with external diodes, so it's a good idea to get into the habit of wiring it correctly regardless of the relay used at the time, you might need to replace the relay with a internal diode style.
The Bosch Rely Standard is 86>12v AND 85>GRND
The Bosch standard style schematic would have the arrow point at the positive coil input.
Cathode > 12V positive
Anode > Ground
Beebe Motorsports
Old 02-15-2011, 11:35 AM   #14
dcw9360
Spooled up
Please check,,, I always thought that the arrow points in the direction of flow of current!!!
Old 02-15-2011, 01:40 PM   #15
gryphon68
gryphon68's Avatar
The diode doesn't pass current when the circuit is completed across the relay.
It's job is to loop the current until it dissipates when the current is removed.
http://www.the12volt.com/relays/relays.asp
Diodes are most often used across the coil to provide a path for current when the current path to the relay is interrupted (i.e. switched off, coil no longer energized). This allows the coil field to collapse without the voltage spike that would otherwise be generated. The diode protects switch or relay contacts and other circuits that may be sensitive to voltage spikes.
Beebe Motorsports
